Serge Posted March 27, 2005 Author Report Share Posted March 27, 2005 Just a little note, jiffy seal tends to be more expensive. I was able to get a roll of peel and seal just last friday for $12.58.←Hmm, that's a pretty significant difference. The local Lowe's doesn't carry Peel and Seal anymore, so I'm out of luck... Link to comment Share on other sites More sharing options...
855T Posted March 28, 2005 Report Share Posted March 28, 2005 Why does the Lowes here carry *nothing*? Bah, my tailgate sounds like it's filled with shredded plastic. Link to comment Share on other sites More sharing options...
Bing_0 Posted March 28, 2005 Report Share Posted March 28, 2005 okay, hehe, maybe i should make osething clear, peel and seal is by no means the end all product out there, i merely like it cause its mad cheap and easy to work with and i can get it very easily in 100 sq foot rolls.basiclaly, any acoustical damper will work, be it silver, black, purple or torquoise...basically, if it sticky, easay to work with, it will work fine in your car so...if you can find something that fits the discription, go for it Bing Link to comment Share on other sites More sharing options...
Veneficus Posted March 28, 2005 Report Share Posted March 28, 2005 i merely like it cause its mad cheap ←We have a winner! Link to comment Share on other sites More sharing options...
Mudman Posted March 30, 2005 Report Share Posted March 30, 2005 Lowe's no longer carries Peel n Seal apparently. They said they carry an alternative that they say is thicker, stickier but slightly messier (because of the added stickiness). It should have the aluminum backing, right? It's just as cheap, too.. like 15 bucks for a 6" x 30' roll.←Fibre Glass-Evercoat makes pads in 12x12 og 16x16,These are alot less than dyna mat, you can find then at almost any autobody supplier. Link to comment Share on other sites More sharing options...
Serge Posted March 30, 2005 Author Report Share Posted March 30, 2005 BeforeAfterMakes a huge difference.I also did the glove box. I took it out, and put a layer on the bottom, sides, and some on top. Then shoved it back in. I also took apart the door and put a few layers on both sides inside. Now the glove box door has a nice shud and doesn't rattle anymore (probably because it's heavier too). Link to comment Share on other sites More sharing options...
Veneficus Posted March 31, 2005 Report Share Posted March 31, 2005 Make sure you seal up the actual panel itself too. That was the big factor for me. Link to comment Share on other sites More sharing options...
tomtbone Posted March 31, 2005 Report Share Posted March 31, 2005 I am having problems finding peel and seal and Jiffy Seal or anything similar to it. WHen I go to Lowe's or Home Depot, what section should I look in for this stuff. I called Lowe's today and they said they don't carry Jiffy Seal. Link to comment Share on other sites More sharing options...
Serge Posted March 31, 2005 Author Report Share Posted March 31, 2005 I am having problems finding peel and seal and Jiffy Seal or anything similar to it. WHen I go to Lowe's or Home Depot, what section should I look in for this stuff. I called Lowe's today and they said they don't carry Jiffy Seal.←It is usually in the roofing department. Link to comment Share on other sites More sharing options...
Serge Posted March 31, 2005 Author Report Share Posted March 31, 2005 Make sure you seal up the actual panel itself too. That was the big factor for me.←Hmm, that's a good idea. Just worried about clearance. Link to comment Share on other sites More sharing options...
Kashif Posted March 31, 2005 Report Share Posted March 31, 2005 I did this recently but I did not cover the galvanized part near the window motor. Does coverage here really make a big difference? The reason I am asking is because when I did the peel and seal, I did not not that much of a difference. Link to comment Share on other sites More sharing options...
Serge Posted March 31, 2005 Author Report Share Posted March 31, 2005 I did it just because it was another part that can rattle. On top of that, I was more interested in the contact between the metal and panel. But it definitely has made a difference. I can crank it up a lot louder and actually enjoy bass. Instead of crappy rattling. Link to comment Share on other sites More sharing options...
tomtbone Posted March 31, 2005 Report Share Posted March 31, 2005 The lowe's by me had a bunch of cases of the peel and seal, so I am hooked up.I am installing some polk ex3550 components today so I am pretty stoked. Tbone Link to comment Share on other sites More sharing options...
jroot Posted April 4, 2005 Report Share Posted April 4, 2005 The lowe's by me had a bunch of cases of the peel and seal, so I am hooked up.I am installing some polk ex3550 components today so I am pretty stoked. Tbone←The one in Woburn? That's usually where I get mine...they seem to always have peel n seel in stock. I need to do more this spring/summer...By the way, you live in watertown? I'm suprised I never see your car, I'm always in that area...I live on Belmont/Cambridge line (Huron Tower as you may know it..) Link to comment Share on other sites More sharing options...
tomtbone Posted April 4, 2005 Report Share Posted April 4, 2005 The one in Woburn? That's usually where I get mine...they seem to always have peel n seel in stock. I need to do more this spring/summer...By the way, you live in watertown? I'm suprised I never see your car, I'm always in that area...I live on Belmont/Cambridge line (Huron Tower as you may know it..)←I bought the peel'n' seal from the one in Milford. Yeah I live right on the Watertown/Belmont border right off of belmont st.I jsut saw a yellow 850 R by Milford getting off of 495 yesterday too. I wonder who's it is. hmmm :ph34r: Link to comment Share on other sites More sharing options...
