Stevesvolvo Posted March 26, 2015 Report Share Posted March 26, 2015 Hi ,This is a strange one, I recently decided to put a new battery on my Saffron V70R. Drove into town then back home with my new purchase. Removed old battery and put new on. Put radio codes in . Tried to start car and the engine spins but will not fire at all.Have pulled all fuses and checked.Have tried starting with immobiliser fuse out.Have locked/unlocked with transponder numerous times.Have checked fuel pressure on railHave checked there is a sparkWill not start! Any ideas? Thanks Link to comment Share on other sites More sharing options...
flyfishing31568908306 Posted March 26, 2015 Report Share Posted March 26, 2015 looked at dist, rotor etc. may have bumped that? smell gas? car have a MSD ign? may have bumped that too. Link to comment Share on other sites More sharing options...
Stevesvolvo Posted March 28, 2015 Author Report Share Posted March 28, 2015 I took dizzy cap off to check contacts Not sure what msd ign means? Link to comment Share on other sites More sharing options...
jcadlols Posted March 31, 2015 Report Share Posted March 31, 2015 Try jumping / closing the main relay. The safest way to do it (in my opinion at least), because the current going through it is huge, is to remove it's plastic cover & manually shut the relay. Making a jumper is difficult as the spade connectors you would need would have to be about 15mm. If that works, the diode in it has likely fried. As a stop gap measure, until you can get a new relay, the diode can be removed and the relay will work. I should add that if you need to shut the relay, you can wedge a pin in there to keep it shut, for long enough to drive to get the parts / to test whether it works. Link to comment Share on other sites More sharing options...
Stevesvolvo Posted May 9, 2015 Author Report Share Posted May 9, 2015 Cam sensor. It's always the cam sensor ! Link to comment Share on other sites More sharing options...
Stumptown Jim Posted June 5, 2015 Report Share Posted June 5, 2015 My guess is that a wire related to the battery was not reinstalled correctly. Link to comment Share on other sites More sharing options...
jessv7098 Posted September 15, 2015 Report Share Posted September 15, 2015 I'm having similar problem I replaced the o2 sensors and now it won't start when I get it to run it runs for a minute or 2 then back to not running Link to comment Share on other sites More sharing options...
