olfac87 Posted June 21, 2015 Report Share Posted June 21, 2015 2007 R wagon. I just completed the 112500k inspection. I noticed that the passenger rear strut was coated in grime, starting as far up the strut as I could see (laying on my back on the ground and looking up) and working downward. I replaced the strut at 85k, which was just about 1.5 years ago. Is it possible the strut is leaking so soon? Could it be something else? Thank you.2007 R wagon. I just completed the 112500k inspection. I noticed that the passenger rear strut was coated in grime, starting as far up the strut as I could see (laying on my back on the ground and looking up) and working downward. I replaced the strut at 85k, which was just about 1.5 years ago. Is it possible the strut is leaking so soon? Could it be something else? Thank you. Oops, I meant shock. (Looks the fronts are called struts and the rears called shocks.) Link to comment Share on other sites More sharing options...
Tzantushka1568908311 Posted June 22, 2015 Report Share Posted June 22, 2015 Could be...There's nothing else back there that leaks oil! Suggest you give it a good degrease and clean down and inspect in a few hundred miles. Link to comment Share on other sites More sharing options...
NEU Posted June 22, 2015 Report Share Posted June 22, 2015 Passenger side suspension components take a beating with our roads. Maybe you hit a pothole hard enough to bust it? With the beltway repaving on the interloop I'm surprised that I don't have something that's broken. In the past know my passenger side suspension parts bust before the drivers side does (endlinks, sturts, shocks, bushings, bearings, etc...) Link to comment Share on other sites More sharing options...
olfac87 Posted July 22, 2015 Author Report Share Posted July 22, 2015 Thanks Tzantushka and Neu. And sorry about the late response. I appreciate both your replies. Looking at the car on the long trip I just took, the right side rear definitely is lower than the left. Looks like I need to replace. I read somewhere I should do both at the same time. Is that true, or given they are relatively new I can just replace the one? Link to comment Share on other sites More sharing options...
Tzantushka1568908311 Posted July 22, 2015 Report Share Posted July 22, 2015 Best practice is both at the same time. With that mileage, and if my budget allowed, I would replace both. Link to comment Share on other sites More sharing options...
JRL Posted August 7, 2015 Report Share Posted August 7, 2015 Volvo parts are guaranteed for 2 years, 24K miles nowWhere did you buy it? Link to comment Share on other sites More sharing options...
