Scott V70R Posted August 12, 2015 Report Share Posted August 12, 2015 Is there a trick to replacing the rear shocks with the 4c? I have the jump seat in the back and I looked at the top mounting location. It seams that the shocks are mounted to a cast aluminum piece. This is then mounted to the body, The issue is that the nut for the top of the shock does not line up with the opening in the body at the top. The triangular openings do not line up. I thought you just loosen the top nut and the bottom bolt, but am I supposed to remove the cast housing and shock as a unit? Does not seem it should be this complex. Looked and cannot find directions for the v70r online. Thanks Link to comment Share on other sites More sharing options...
Scott V70R Posted August 14, 2015 Author Report Share Posted August 14, 2015 Found my answer here. http://forums.swedespeed,com/showthread.php?177100-Rear-Suspension-Removal It is a bit tricky. Particularly when you are reassembling and disconnecting the electrical connectors. One side down and one to go. Link to comment Share on other sites More sharing options...
