Kelalper Posted July 12, 2004 Report Share Posted July 12, 2004 Thanks a lot. Also many thanks for how to. I am gonna mount a water spray system. I dont think that i can find a bigger intercooler in Turkey. Link to comment Share on other sites More sharing options...
Travis3265 Posted August 18, 2004 Report Share Posted August 18, 2004 i have a question about running an MBC in conjunction with the Upsolute ECU. will boosting 1-2psi over what the car will be boosting with the Upsolute software trip the check engine light?im planning on chipping my ecu next week and havin an MBC installed as well to boost just a little bit more, but i dont want a CEL on because of it. Link to comment Share on other sites More sharing options...
Junior1568908558 Posted September 9, 2004 Report Share Posted September 9, 2004 The danger with this type of tune is that the heat inside the engine increase quite alot.. the harder you push your engine, and more heat above the pistons you have... and chanses for the pistons to melt is 50 % bigger. We have had 2 members with a complete engine melt-down, if u are gonna use this.. please install a turbo gauge so you have control. otherwise its gonna be expensive! Trust me.. Link to comment Share on other sites More sharing options...
FluidGroove Posted September 14, 2004 Report Share Posted September 14, 2004 Travis3265 wrote on Wed, 18 August 2004 15:21i have a question about running an MBC in conjunction with the Upsolute ECU. will boosting 1-2psi over what the car will be boosting with the Upsolute software trip the check engine light?im planning on chipping my ecu next week and havin an MBC installed as well to boost just a little bit more, but i dont want a CEL on because of it.you dont need to boost more with an upsolute if your running the stock 12T turbo. it just runs out of steam and is inefficient. unless you have intercooler, downpipe, exhaust, and air filter i wouldnt boost over 12-15 psi Link to comment Share on other sites More sharing options...
janis1568908554 Posted September 14, 2004 Report Share Posted September 14, 2004 Junior wrote on Thu, 09 September 2004 16:46The danger with this type of tune is that the heat inside the engine increase quite alot.. the harder you push your engine, and more heat above the pistons you have... and chanses for the pistons to melt is 50 % bigger. We have had 2 members with a complete engine melt-down, if u are gonna use this.. please install a turbo gauge so you have control. otherwise its gonna be expensive! Trust me.. How about Water Injection. I don't wanna sound like an aquamist commercial, but if you guys run a lot of boost an heat is the first danger, cool it! Link to comment Share on other sites More sharing options...
Junior1568908558 Posted September 14, 2004 Report Share Posted September 14, 2004 'm not suer it will work with the boost control. True its the heat that is the first danger but its because the wastegate wont let go with the pressure from the turbo... Link to comment Share on other sites More sharing options...
s40R1568908553 Posted September 15, 2004 Report Share Posted September 15, 2004 Junior wrote on Tue, 14 September 2004 09:06'm not suer it will work with the boost control. True its the heat that is the first danger but its because the wastegate wont let go with the pressure from the turbo...Aquamist test results:Lowers cylinder temps by as much as 300 degree Fahrenheit = 148.8888889 degree Celsius. If it cools cylinder temps it's a step in the right direction. The unit is programmable(by boost levels) so you can optimize when you want water injection to kick in. Will work with a boost controller. Link to comment Share on other sites More sharing options...
janis1568908554 Posted September 15, 2004 Report Share Posted September 15, 2004 Junior wrote on Tue, 14 September 2004 10:06'm not suer it will work with the boost control. True its the heat that is the first danger but its because the wastegate wont let go with the pressure from the turbo...Don't know why it wouldn't work.The 1S aquamist is triggered by an adjustable pressure switch.If you run 1.5 bar of boost you can set the switch to activate at 1.1 or 1.2 bar.I use aquamist and a boost controller (not at 1.5 bar though,....yet ) Link to comment Share on other sites More sharing options...
Junior1568908558 Posted September 15, 2004 Report Share Posted September 15, 2004 s40R wrote on Wed, 15 September 2004 07:46Junior wrote on Tue, 14 September 2004 09:06'm not suer it will work with the boost control. True its the heat that is the first danger but its because the wastegate wont let go with the pressure from the turbo...Aquamist test results:Lowers cylinder temps by as much as 300 degree Fahrenheit = 148.8888889 degree Celsius. If it cools cylinder temps it's a step in the right direction. The unit is programmable(by boost levels) so you can optimize when you want water injection to kick in. Will work with a boost controller.Ok, then I surrender... Will not argue about something i'm not 100 % positive sure! Ok then it will work with water injection.... Link to comment Share on other sites More sharing options...
janis1568908554 Posted September 15, 2004 Report Share Posted September 15, 2004 Junior wrote on Wed, 15 September 2004 10:21Ok, then I surrender... Will not argue about something i'm not 100 % positive sure! Ok then it will work with water injection.... Sounds like you are going to put your newfound knowledge to good use. Link to comment Share on other sites More sharing options...
Junior1568908558 Posted September 15, 2004 Report Share Posted September 15, 2004 janis wrote on Wed, 15 September 2004 20:54Junior wrote on Wed, 15 September 2004 10:21Ok, then I surrender... Will not argue about something i'm not 100 % positive sure! Ok then it will work with water injection.... Sounds like you are going to put your newfound knowledge to good use. No not right now, I have tons of payments to do first. But I sure like the idea of it Link to comment Share on other sites More sharing options...
S40_Flyer Posted September 17, 2004 Report Share Posted September 17, 2004 How well does that aquamist or whatever work? Are the gains worht it, I mean, obviously they help some since you have it installed, but what are the gains... Link to comment Share on other sites More sharing options...
janis1568908554 Posted September 17, 2004 Report Share Posted September 17, 2004 S40_Flyer wrote on Fri, 17 September 2004 06:25How well does that aquamist or whatever work? Are the gains worht it, I mean, obviously they help some since you have it installed, but what are the gains... Compared to an upsolute chip, in terms of HP/dollar it's too expensive.Just installing WI won't gain much. If you add a lot of Methanol it might. The gain is that you're able to increase boost pressure further than without WI. The knock-limit is raised because of the water, timing can be adjusted.I mainly have it for peace of mind. Future tuning would/could really benefit from WI.Check out the WI forum, lot's of people adjusting air/fuel ratios, inceasing boost and gaining a lot of power. But just adding the WI add's some power, but not much.http://www.waterinjection.info/phpBB2/Still, I love it! (despite the reservoir problems I had).JanisThose 1.5bar people, they NEED it. Link to comment Share on other sites More sharing options...
S40_Flyer Posted September 22, 2004 Report Share Posted September 22, 2004 Thanks for the info man... Link to comment Share on other sites More sharing options...
Kelalper Posted September 23, 2004 Report Share Posted September 23, 2004 what about electronic boost controllers.Have you ever used them. I am thinking to buy Apexi turbo timer and boost controller units. But i hesitate for mounting the boost controller. I dont know what extra parts i need for mounting it. Link to comment Share on other sites More sharing options...
