s40-sick-o Posted May 25, 2005 Report Share Posted May 25, 2005 I got everything hooked up...but whats he BCS? The pic will help...its at 12.5ish PSI. Link to comment Share on other sites More sharing options...
S40Monster1568908557 Posted May 25, 2005 Report Share Posted May 25, 2005 BCS is the boost control solenoid. I'll get pictures when I can. Link to comment Share on other sites More sharing options...
s40-sick-o Posted May 25, 2005 Report Share Posted May 25, 2005 S40Monster wrote on Tue, 24 May 2005 20:29BCS is the boost control solenoid. I'll get pictures when I can.Ok thanks. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted July 8, 2005 Report Share Posted July 8, 2005 DId you take the pictures without boostcontrol solenoid? Link to comment Share on other sites More sharing options...
S40Monster1568908557 Posted July 8, 2005 Report Share Posted July 8, 2005 I'll see if I can't borrow my roommates digi camera when he gets home and help you guys out. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted July 8, 2005 Report Share Posted July 8, 2005 Could you explain it on words? Link to comment Share on other sites More sharing options...
S40Monster1568908557 Posted July 8, 2005 Report Share Posted July 8, 2005 I already have.S40Monster wrote on Sat, 23 April 2005 02:51Old topic, but I dealt with this issue recently and figured I'd throw up the answer. You take the line running to the intake and simply remove it, then plug the hole that's in your intake. The line that was running to the wastegate actuator you plug into the output of the MBC, and you plug the remaining line into the input. What do with the actual sensor I haven't quite figured out, the car will run with it removed from the car, but I'm not sure what effect if any this has on the car. I'm not sure if I should reinstall it and cap it, or just leave it as is.Another update, cap off your BCS and leave it plugged in. Removing it from the car completely with throw all sorts of engine codes. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted July 9, 2005 Report Share Posted July 9, 2005 Wow i got it working with out original boost control solenoid. Turbo lag is gone and car feels so fast right now. Ill post picture of the connection soon. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted July 9, 2005 Report Share Posted July 9, 2005 There is the picture what i promised. 1.1bar constant now on my car. Link to comment Share on other sites More sharing options...
Eese Posted July 10, 2005 Report Share Posted July 10, 2005 S40Monster wrote on Wed, 25 May 2005 02:41I have found that the best way to install is to remove the BCS then cap off the hole left in the intake and all three vacuum connections on the BCS, however leave it plugged in to the harness. Then run the line coming from your turbo to the input of the MBC and the line going to the wastegate actuator on the output. I can take pictures if it will help, but it's really pretty self explanitory what's you get in there.What´s the difference on those installations..? MBC with removed BCS vs. MBC with BCS?? Link to comment Share on other sites More sharing options...
S40Monster1568908557 Posted July 10, 2005 Report Share Posted July 10, 2005 With capped BCS I'm not throwing an overboost code. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted July 10, 2005 Report Share Posted July 10, 2005 I noticed that without the original BCS and only with MBC the boost rises even faster than with bcs. And no boost spikes. My MBC works better without original BCS. Believe me now Eese. Link to comment Share on other sites More sharing options...
Eese Posted July 10, 2005 Report Share Posted July 10, 2005 So, i think i´ll have to try...I´m happy with my current setup tho...So, what do i disconnect?NOTICE!!! COLORS MAY NOT BE RIGHT...just added them to help you guys explain what to do. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted July 10, 2005 Report Share Posted July 10, 2005 The blue and yellow are wrong way on your picture eese.You just disconnect all pipes of the BCS and plug them. Then leave it hanging with power cable connected on BCS.Then just connect red line to mbc input and yellow to output and your all good. No warning lights and no problems. Remember leave original BCS with power cable on. Link to comment Share on other sites More sharing options...
Eese Posted July 10, 2005 Report Share Posted July 10, 2005 Oliko ohjeet sen mukaan miten kuvassa oli värit, vai sen mukaan miten ne oikeasti on merkitty, eli keltainen ja sininen toisinpäin?Sorry guys, i had to write some finnish to make sure i won´t screw up this. Link to comment Share on other sites More sharing options...
