Guest DougK Posted March 30, 2005 Report Share Posted March 30, 2005 i guess it is the rca cable, i used a Y addaptor and connected the suposidly good channel cable to the amp, it did not go into protection even at the highest level input. i tried the otehr channel, it also didnt go into protection but the volum is less at the same input level. bass boost is 0db , oh well im going to get a new rca and try again.should the rca cables have same volum on them? and is the base signal sent to both channels at the same level(mono)?←Its possible that pulling on the RCA's to run them or whatever broke a connection ect. Link to comment Share on other sites More sharing options...
highhighs Posted March 30, 2005 Author Report Share Posted March 30, 2005 i retried today, if i connrct both channels of teh rca cable it goes into protection mode, if i connect either channel alone using the Y addaptor it does not go into prot. mode.i baught a new cable but no time to try it so till later.but thier is a thing: how do u know when its clipping, i have the preamp out of the HU 2V but when i was adjusting the input level , even at the highest setting i didnt hear any clipping (or i didnt know it was clipping). the bass became a little loose but..., both the amp and the sub are 300Wrms. Link to comment Share on other sites More sharing options...
bogelo Posted March 30, 2005 Report Share Posted March 30, 2005 How many subs are you running? Seems to me (from your diagram) that you are only running 1 subwoofer.If you are running mono bridge, check your amplifier manual. Some amplifier only need input on 1 channel (usually right channel). Link to comment Share on other sites More sharing options...
highhighs Posted March 30, 2005 Author Report Share Posted March 30, 2005 How many subs are you running? Seems to me (from your diagram) that you are only running 1 subwoofer.If you are running mono bridge, check your amplifier manual. Some amplifier only need input on 1 channel (usually right channel).←yes i have 1 sub running bridged, the catalog states to use a Yadaptor but it does not state which channel from the HU to use. also any help about clipping?another thing where is a safe place to screw the sub box or how do u mount ur sub box in the truck, its a ocatagon(8 sides?) ported box. Link to comment Share on other sites More sharing options...
bogelo Posted March 31, 2005 Report Share Posted March 31, 2005 yes i have 1 sub running bridged, the catalog states to use a Yadaptor but it does not state which channel from the HU to use. also any help about clipping?another thing where is a safe place to screw the sub box or how do u mount ur sub box in the truck, its a ocatagon(8 sides?) ported box.←So your HU has 2-ch output for Low-pass (subwoofer)? Need a full & detail diagram on how your system set-up or maybe a scan of your amp' manual. Everything is vague as of right now.You can use an L-shaped plates to mount your box. But always check what's underneath before you mount anything. Link to comment Share on other sites More sharing options...
