Guest RK from OR Posted March 28, 2005 Report Share Posted March 28, 2005 For those who are thinking of getting new speakers for the rear deck in their 854s but want to keep a stock look, here's what I have done.Last year I installed a Nakamichi deck, a pair of Boston NX 57 (5.25 in) speakers for the doors, and an Alpine amp. The whole thing sounds much better than stock. I didn’t change the rear speakers mainly because of the strange size of the OE speakers. I want to keep the installation as simple as possible without cutting the rear deck or the metal underneath. I didn’t want a sub because of trunk space issue and I don’t really need that much bass. Plus, after I added an amp, the rear OE speakers did sound a little bit better so I just left them alone. Now I finally decided to change the rear spkrs. I bought a pair of Infinity 5x7/6x8 but they were too small. So I returned them and got a pair of 6x9 but the magnets were too big for the OE box. Then I remembered the Boston NX series use Neodymium magnets which are much smaller than the conventional magnets. So I bought a pair of Boston NX97 (6x9) and they fit almost perfectly. The 4 mounting screws, the height, the magnets size all fit perfectly. The only problem is the OE box is a bit too small for 6x9s to be mounted IN the box. It also required a plate for spkrs to mount on to separate the front and the back wave (the OE spkrs and the mounting surface are built together). I went to Home Depot and bought a piece of plywood (1/8 in thick) for $1.50. After spending over an hour measuring and cutting the ply wood, I finally mounted the spkrs onto the box with the plywood in between. The sound is awesome. The sound is more balanced, has better bass, and cleaner vocals and highs. Only then I realized the OE spkrs really suck. If I knew it would sound this good, I wouldn’t have waited that long. Now I just need to paint the plywood black and put something to fill the gap. I took some of the pictures but how do you post pictures here?? RK from OR Link to comment Share on other sites More sharing options...
Plan_B Posted March 28, 2005 Report Share Posted March 28, 2005 Oregon!.......what part of Oregon are you from? Link to comment Share on other sites More sharing options...
theunderlord Posted March 28, 2005 Report Share Posted March 28, 2005 I took some of the pictures but how do you post pictures here?? RK from OR←the same way you post pictures on any website. www.photobucket.com Link to comment Share on other sites More sharing options...
Guest Guest Posted March 28, 2005 Report Share Posted March 28, 2005 98S70R, I thought I could just copy and paste the photos in here. But thanks for the link. Learned something new today Here are the links to the photos:http://i3.photobucket.com/albums/y81/veloce426/1.jpghttp://i3.photobucket.com/albums/y81/veloce426/boston2.jpghttp://i3.photobucket.com/albums/y81/veloce426/back2.jpghttp://i3.photobucket.com/albums/y81/veloce426/side.jpgFast_box,From Beaverton/Portland. We met already when I posted "the rattling sound from rear seat" a few weeks back :D Link to comment Share on other sites More sharing options...
theunderlord Posted March 28, 2005 Report Share Posted March 28, 2005 98S70R, I thought I could just copy and paste the photos in here. But thanks for the link. Learned something new today ←excellent, you can copy and paste.. do what you just did, just put {img} {/imh} tags around the URL to the pic... of course, use "[ ]" rather than {} Link to comment Share on other sites More sharing options...
