Slater Posted March 31, 2005 Report Share Posted March 31, 2005 OK, so I installed the IPD sway bars on my car last night (rear only for now - I have other plans for the front).IPD advertises their bar as a 22mm bar, and my micrometer verified - 22.45mm.Well guess what - I measured my stock sway bar and it is 22.51mm. Now, the slight difference is due to the thickness of the paint. The point is that the stock T-5R was supposed to come with a 20.8mm rear bar.And no the previous owner did not have an aftermarket bar on there. It's bone stock just like it rolled out of the factory.I wondered why I felt ZERO difference when I changed out the sway bar. I WOULD feel the difference between a 20.8 and 22mm bar (22mm sway bar is 125.15% stiffer than a 20.8mm sway bar).That pissed me off because it throws a wrench into my plans and wasn't exactly the cheapest thing I've ever bought...Something fishy is going on, and I haven't figured out what yet. My micrometer is correct. I have a feeling the sway bar sizes everyone has been quoting for all of the different models and years is incorrect. Which doesn't make any sense because I'm sure the list was compiled directly from Volvo information.- Slater Link to comment Share on other sites More sharing options...
Plan_B Posted March 31, 2005 Report Share Posted March 31, 2005 I put the IPD bars on my car two weeks ago, I have noticed a huge difference in teh handeling and the preformance. I am sorry you are having these issues. :huh: Link to comment Share on other sites More sharing options...
shaun Posted March 31, 2005 Report Share Posted March 31, 2005 OK, so I installed the IPD sway bars on my car last night (rear only for now - I have other plans for the front).IPD advertises their bar as a 22mm bar, and my micrometer verified - 22.45mm.Well guess what - I measured my stock sway bar and it is 22.51mm. Now, the slight difference is due to the thickness of the paint. The point is that the stock T-5R was supposed to come with a 20.8mm rear bar.And no the previous owner did not have an aftermarket bar on there. It's bone stock just like it rolled out of the factory.I wondered why I felt ZERO difference when I changed out the sway bar. I WOULD feel the difference between a 20.8 and 22mm bar (22mm sway bar is 125.15% stiffer than a 20.8mm sway bar).That pissed me off because it throws a wrench into my plans and wasn't exactly the cheapest thing I've ever bought...Something fishy is going on, and I haven't figured out what yet. My micrometer is correct. I have a feeling the sway bar sizes everyone has been quoting for all of the different models and years is incorrect. Which doesn't make any sense because I'm sure the list was compiled directly from Volvo information.- Slater←Same thing on my car (855 t5r)- IPD unit was different but the bar that did the work was the same dia as the stock unit. Link to comment Share on other sites More sharing options...
Zappo Posted March 31, 2005 Report Share Posted March 31, 2005 Grant, you put them front and rear, so you would notice the difference.So far, I have only done my rear bar, and I found exactly the same thing. It seemed to be almost the same size. I didn't have a micrometer, I used a 22mm wrench. After I installed it, I couldn't tell a difference at all.That said, the IPD bar is constructed better than the stock one. Mounting points are much beefier. Link to comment Share on other sites More sharing options...
Plan_B Posted April 1, 2005 Report Share Posted April 1, 2005 Grant, you put them front and rear, so you would notice the difference.So far, I have only done my rear bar, and I found exactly the same thing. It seemed to be almost the same size. I didn't have a micrometer, I used a 22mm wrench. After I installed it, I couldn't tell a difference at all.That said, the IPD bar is constructed better than the stock one. Mounting points are much beefier.←Well, I don't much about mm and whatnot, but my car handles so much better then it did before. :D Link to comment Share on other sites More sharing options...
Slater Posted April 1, 2005 Author Report Share Posted April 1, 2005 Grant, you put them front and rear, so you would notice the difference.So far, I have only done my rear bar, and I found exactly the same thing. It seemed to be almost the same size. I didn't have a micrometer, I used a 22mm wrench. After I installed it, I couldn't tell a difference at all.That said, the IPD bar is constructed better than the stock one. Mounting points are much beefier.←You're right - the stock one is ridiculously thin and flimsy as far as the mounting points.I am not planning on using the IPD front bar, but rather installing poly or delrin bushings on the stock front bar. In fact, I am planning on installing the SMALLER 20mm front bar found on the base models in an effort to get rid of the ridiculous understeer. The huge 25mm IPD bar will only make it worse. Link to comment Share on other sites More sharing options...
Zappo Posted April 1, 2005 Report Share Posted April 1, 2005 You're right - the stock one is ridiculously thin and flimsy as far as the mounting points.I am not planning on using the IPD front bar, but rather installing poly or delrin bushings on the stock front bar. In fact, I am planning on installing the SMALLER 20mm front bar found on the base models in an effort to get rid of the ridiculous understeer. The huge 25mm IPD bar will only make it worse.←Ahh. Well, I am sure you can sell the IPD front bar easily.I am planning on installing my front bar tomorrow. After that I am sure I will notice a big difference, and probably notice even more understeer than normal. Link to comment Share on other sites More sharing options...
shaun Posted April 1, 2005 Report Share Posted April 1, 2005 Ahh. Well, I am sure you can sell the IPD front bar easily.I am planning on installing my front bar tomorrow. After that I am sure I will notice a big difference, and probably notice even more understeer than normal.← Link to comment Share on other sites More sharing options...
PullMyFinger Posted April 1, 2005 Report Share Posted April 1, 2005 With the ipd rear and the stock front I had crazy amounts of oversteer. Twitchy and downright hazardous at freeway speeds. It makes for a great autocross setup though.I'm much happier with ipds front and rear although I have not really pushed the car very hard yet. Waiting for non wet roads. Link to comment Share on other sites More sharing options...
VolFan Posted April 1, 2005 Report Share Posted April 1, 2005 My R bar was Hollow Tubbing , and the IPD bar is Solid Shaft. I also checked mine with a Dial Caliper, and it was the same. Don't forget the IPD bar is heavier :blink: Link to comment Share on other sites More sharing options...
GShyneDM Posted April 1, 2005 Report Share Posted April 1, 2005 If you can... head on underneath your car and check the measurements of your front sway bar... Also check the rear bar that you freshly installed tooJUST to be sure... Link to comment Share on other sites More sharing options...
Slater Posted April 1, 2005 Author Report Share Posted April 1, 2005 With the ipd rear and the stock front I had crazy amounts of oversteer. Twitchy and downright hazardous at freeway speeds. It makes for a great autocross setup though.I'm much happier with ipds front and rear although I have not really pushed the car very hard yet. Waiting for non wet roads.←I couldn't get mine to oversteer for anything. Link to comment Share on other sites More sharing options...
Slater Posted April 1, 2005 Author Report Share Posted April 1, 2005 If you can... head on underneath your car and check the measurements of your front sway bar... Also check the rear bar that you freshly installed tooJUST to be sure...←I just did - this morning.Freshly installed rear IPD bar = 22.45mm.Stock rear sway bar I just removed = 22.51mm. Link to comment Share on other sites More sharing options...
VolFan Posted April 1, 2005 Report Share Posted April 1, 2005 I just did - this morning.Freshly installed rear IPD bar = 22.45mm.Stock rear sway bar I just removed = 22.51mm.←What about it being HOLLOW? Link to comment Share on other sites More sharing options...
Slater Posted April 1, 2005 Author Report Share Posted April 1, 2005 My R bar was Hollow Tubbing , and the IPD bar is Solid Shaft. I also checked mine with a Dial Caliper, and it was the same. Don't forget the IPD bar is heavier ←Hold on now, that would explain it.You SURE about that? The stock bar felt awful heavy.If that is the case then yes, the IPD bar is SIGNIFICANTLY stiffer. Unfortunately I can't calculate the difference without knowing the ID of the stock bar (if it in fact hollow).To calculate sway bar stiffness, you take:Larger bar diameter to the 4th power/Smaller bar diameter to the 4th power * 100 = % change in stiffness.However that only works when comparing solid vs solid or hollow vs hollow. When you compare solid vs hollow you have an extra calculation:After you have calculated the rate of the hollow bar based on its outside diameter (o.d.), you have to subtract the rate of a hypothetical bar that matches the inside diameter (i.d.) of the space within. To do that, you need to know the wall thickness of the hollow bar which unfortnately I don't know without cutting it apart. Although if I stop by an official NHRA track, they will have an ultrasonic wall thickness measurer (used for verifying that roll cares are not really just lighter muffler tubing of the same OD as chromoly cage tubing but at a significant weight savings - old time cheating trick).- Slater Link to comment Share on other sites More sharing options...
