Karlson Posted April 1, 2005 Report Share Posted April 1, 2005 Wow SlaterThats a pretty strange, i thought R sway bars is almost the same as Turbo one. But may be u can sell your R sways :) Link to comment Share on other sites More sharing options...
Plan_B Posted April 1, 2005 Report Share Posted April 1, 2005 :D Link to comment Share on other sites More sharing options...
Karlson Posted April 1, 2005 Report Share Posted April 1, 2005 NO!!!not again, u already asked dumb question last night! Link to comment Share on other sites More sharing options...
Plan_B Posted April 1, 2005 Report Share Posted April 1, 2005 NO!!!not again, u already asked dumb question last nigh!←Shutit I found out anyway ;) Link to comment Share on other sites More sharing options...
StansMan Posted April 1, 2005 Report Share Posted April 1, 2005 Hollow bars are only stiffer if larger diamater.A solid bar of the same diamater will ALWAYS be stiffer than a hollow bar of the SAME diameter.That's why you see some aftermarket hollow bars that are HUGE - like giant pieces of pipe. It's because they must be that way to get the same stiffness per inch as a solid bar of a much smaller diamater.←As long as they're made of the same material. Ah, reading all this takes me back to my statics class :( Link to comment Share on other sites More sharing options...
Karlson Posted April 1, 2005 Report Share Posted April 1, 2005 u shut it!good for u that u found out Link to comment Share on other sites More sharing options...
Slater Posted April 1, 2005 Author Report Share Posted April 1, 2005 As long as they're made of the same material. Ah, reading all this takes me back to my statics class ←They are both plain steel. The only thing you could do is heat treat it, but you can tell by looking at the bar that it is not heat treated.- Slater Link to comment Share on other sites More sharing options...
Geevs Posted April 1, 2005 Report Share Posted April 1, 2005 I just measured my set of R sway bars - the front is 21mm. It is uninstalled so I was able to check if it was hollow by tapping it w/ a hammer but it did NOT sound hollow. It sounded and felt like it was solid iron. The rears are installed and I recall measuring them before putting them on - they were also 21mm which I surprised me cause it's thicker than the Volvo specs. I agree w/ Slater that this could be from the rubberized paint adding thickness. So there. Link to comment Share on other sites More sharing options...
AutoX47 Posted April 1, 2005 Report Share Posted April 1, 2005 the way you take the turn makes a big difference in the car's traction, maybe you guys need to take turns a little wider. Of course if you early apex and then try to cut the wheel you are going to understeer Link to comment Share on other sites More sharing options...
Slater Posted April 1, 2005 Author Report Share Posted April 1, 2005 the way you take the turn makes a big difference in the car's traction, maybe you guys need to take turns a little wider. Of course if you early apex and then try to cut the wheel you are going to understeer←What sway bar configuration are you referring to?You're exactly right on the apexing...it's harder to do with R compound tires though. Link to comment Share on other sites More sharing options...
Slater Posted April 1, 2005 Author Report Share Posted April 1, 2005 I just measured my set of R sway bars - the front is 21mm. It is uninstalled so I was able to check if it was hollow by tapping it w/ a hammer but it did NOT sound hollow. It sounded and felt like it was solid iron. The rears are installed and I recall measuring them before putting them on - they were also 21mm which I surprised me cause it's thicker than the Volvo specs. I agree w/ Slater that this could be from the rubberized paint adding thickness. So there.←Nah, you're not going to get that much buildup. Most paint is a few thou at the most. Plus it's already been taken into account on the measurements i took. That's why I was getting 22.4mm on IPDs "22mm" bar.So if your bar measured 21mm that means it's 20.something.- Slater Link to comment Share on other sites More sharing options...
Che'_Moderator Posted April 1, 2005 Report Share Posted April 1, 2005 Just as an aside, my 95R bars are the same size as the IPD bars. Thats why I never bothered with IPD. They are also solid, I remember making torsion bars with a set and they are solid. Link to comment Share on other sites More sharing options...
Slater Posted April 1, 2005 Author Report Share Posted April 1, 2005 Just as an aside, my 95R bars are the same size as the IPD bars. Thats why I never bothered with IPD. They are also solid, I remember making torsion bars with a set and they are solid.←That's I was afraid of. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted April 1, 2005 Report Share Posted April 1, 2005 That's I was afraid of.←No worries. IPDs are prettier Link to comment Share on other sites More sharing options...
Slater Posted April 1, 2005 Author Report Share Posted April 1, 2005 No worries. IPDs are prettier←Baha - don't forget about the nifty decals they sent with the kit - that's worth 5hp right there! Link to comment Share on other sites More sharing options...
