dl744tga Posted April 5, 2004 Report Share Posted April 5, 2004 I have a C70 with the SC 901 radio. After loading the CD's into the cartridge and inserting the cartridge into the radio, the CD's start to load but do not completely load. The 3 CD's constantly cylce through the loading process and none of the three ever load. Any suggestions for fixing this? :( Link to comment Share on other sites More sharing options...
Guest Karen Posted April 6, 2004 Report Share Posted April 6, 2004 I don't know whether this is your problem, but the SC-901 will generally not play home-spun CDs - It is extremely sensitive to recording/medium quality. If you're trying this, you might try slowing your burn down to 1x. If you have good burning software you could also try adjusting the interleave (spacing between tracks - the bigger the better) but even that may not make a difference. If your 901 isn't playing commercially recorded CDs, I would definitely get the system checked. Good Luck. Link to comment Share on other sites More sharing options...
Guest Dazman Posted April 16, 2004 Report Share Posted April 16, 2004 Hi. Just stumbled accros this so appoloies if you already know the answer. I have just aquired C70 with same problem. Found out it was the discs I've been using. Seems 901 does not like the "green" discs. Chnage mine for "silver" and works ok. Does take longer to search between tracks (approx 3 seconds) but otherwise no probs. dazman_1@excite.com Link to comment Share on other sites More sharing options...
