8501995 Posted April 5, 2005 Report Share Posted April 5, 2005 Hi,The "no gas left" indicator was turned on in my car, so I went to the gas station.I tried opening the door to remove the gas cap, but I just can't open the door!I have tried pulling really hard and I just can't do it.Is there anything that could block it? Is there a security lever or something? I have never had to do anything else to fill up the tank!So the car pretty much has to stay in the driveway until I can open that door, because there is no more gas!I have a Volvo 850 GLE 1995 if that can help.Thanks! Link to comment Share on other sites More sharing options...
merlin390 Posted April 5, 2005 Report Share Posted April 5, 2005 unlock the doors. If that still doesnt work pop the truck remove the inner lining on the passenger side and look for the pull handle to release it. Link to comment Share on other sites More sharing options...
8501995 Posted April 5, 2005 Author Report Share Posted April 5, 2005 Ok well the doors were unlocked.Is there a button or something I should do to unlock the door or is my door just stuck?unlock the doors. If that still doesnt work pop the truck remove the inner lining on the passenger side and look for the pull handle to release it.← Link to comment Share on other sites More sharing options...
merlin390 Posted April 5, 2005 Report Share Posted April 5, 2005 Did you pull back the trunk lining on the passenger side of the trunk wall? and locate the metal pull/? Link to comment Share on other sites More sharing options...
850R Sleeper Posted April 5, 2005 Report Share Posted April 5, 2005 Go with Merlin on this one. There is an emergency release switch when you pull back the lining. Try that, mine wouldn't unlock last summer either and that's what I had to do. Good luck. Link to comment Share on other sites More sharing options...
Plan_B Posted April 5, 2005 Report Share Posted April 5, 2005 That's insane, the samething happened to me on Friday night!, I totally freaked and called my mechanic, luckly he was still working!.There is a metal ring next to the passenger rear tail light behind that creepy grey carpet, simply pull on it lightly! :D Link to comment Share on other sites More sharing options...
T5BRICK Posted April 5, 2005 Report Share Posted April 5, 2005 here you go:http://volvospeed.com/Repair/mgasrelease.htmi had the same thing happen to me. Link to comment Share on other sites More sharing options...
8501995 Posted April 5, 2005 Author Report Share Posted April 5, 2005 Ok well that's pretty clear guys, I'll try this out!Thanks a lot! Link to comment Share on other sites More sharing options...
ToxicLemonade Posted April 5, 2005 Report Share Posted April 5, 2005 did you vapor lock it shut? Link to comment Share on other sites More sharing options...
T5BRICK Posted April 5, 2005 Report Share Posted April 5, 2005 did you vapor lock it shut?←he can't get the door open. it has a locking mechanism that got stuck. mine doesn't work at all. Link to comment Share on other sites More sharing options...
prasamin Posted April 5, 2005 Report Share Posted April 5, 2005 mine doesn't work at all either....just left the panel off in my wagon because sometimes it's unlocked, and sometimes not....is there a fix for this? Link to comment Share on other sites More sharing options...
T5BRICK Posted April 5, 2005 Report Share Posted April 5, 2005 you could just unplug the locking mechanism. Link to comment Share on other sites More sharing options...
Guest AlvinL Posted April 5, 2005 Report Share Posted April 5, 2005 It happened top me before too. Try and lock/unlock your doors several times until it unlock. Sometimes it's just sticky. If all else fails then open the tailight cover access in your trunk to locate the ring like it's been described.In the past, with a previous 850, I've taken the motor out and cleaned the connection and re-installed. It's not a soldered connection so just clean the connection and re-insert the connector pins and away you go. Worked like a charm for me anyways... I may have to do this for my T-5R soon. Link to comment Share on other sites More sharing options...
Plan_B Posted April 5, 2005 Report Share Posted April 5, 2005 It happened top me before too. Try and lock/unlock your doors several times until it unlock. Sometimes it's just sticky. If all else fails then open the tailight cover access in your trunk to locate the ring like it's been described.In the past, with a previous 850, I've taken the motor out and cleaned the connection and re-installed. It's not a soldered connection so just clean the connection and re-insert the connector pins and away you go. Worked like a charm for me anyways... I may have to do this for my T-5R soon.←Post some more pictures of your car please :D Link to comment Share on other sites More sharing options...
Patrick. Posted April 5, 2005 Report Share Posted April 5, 2005 okay does my '94 854 even have this locking option for the fuel door?!?! I've never locked/unlocked it, but I also have never tried to open the fuel door w/ the doors locked either... any idea if my car has this option and it just isn't working? Link to comment Share on other sites More sharing options...
