javadoc Posted April 5, 2005 Report Share Posted April 5, 2005 I'm looking to add a 4-channel amp to my system but wanted to see what you guys have done. Right now I'm running my mains with the power from my SC-816 HU, and my 2-8" JLs through a 300W Kenwood sub-amp. My sub-amp is mounted on a small frame that I constructed below the rear deck, and then the subs snick up under the deck. Being a bandpass box, it's bulky, so it takes up all the space below the rear deck, but that's okay w/me.At any rate, I'm trying to think of a good place to mount both amps. My 4-channel amp is a Fosgate that I picked up from a friend. I should get pix of them all, but never have. I'm thinking of mounting the amps in the spare tire well, but that might negate the use of a spare unless I'm really creative... ideas on that?Your pix, ideas and creativity are welcome! My goal is to keep the amps as out of the way as possible. Link to comment Share on other sites More sharing options...
Kibim Posted April 5, 2005 Report Share Posted April 5, 2005 My stock volvo 4ch amp sits under the drivers seat. Link to comment Share on other sites More sharing options...
theunderlord Posted April 5, 2005 Report Share Posted April 5, 2005 Heres some ideas for ya... Link to comment Share on other sites More sharing options...
Deltablade Posted April 5, 2005 Report Share Posted April 5, 2005 You might check out Doug's new setup. Its pretty cool. Link to comment Share on other sites More sharing options...
Kibim Posted April 5, 2005 Report Share Posted April 5, 2005 Kevin, if i went to all the trouble, and still had cables laying about, i'd kill myself! Link to comment Share on other sites More sharing options...
javadoc Posted April 5, 2005 Author Report Share Posted April 5, 2005 Thanks I'll check out Doug's as well.Kevin, that's basically how I have my sub-amp mounted right now, except the rack I used was wood (I was in a rush... never made it better). Isn't it bad to mount your amps upside down b/c of heat, or is that not really true? Nice install, by the way!<Edit> Ditto on the wires. Actually, where are your rear deck speakers and why? Link to comment Share on other sites More sharing options...
theunderlord Posted April 5, 2005 Report Share Posted April 5, 2005 Thanks I'll check out Doug's as well.Kevin, that's basically how I have my sub-amp mounted right now, except the rack I used was wood (I was in a rush... never made it better). Isn't it bad to mount your amps upside down b/c of heat, or is that not really true? Nice install, by the way!<Edit> Ditto on the wires. Actually, where are your rear deck speakers and why?←It's not reccomended, but there is lots of free air, and the rear speakers are pretty pointless if you have a sub, so I just pulled em out. The bass is a little louder now, that and I drive with the pass through down. You could always make that rack go down farther, and mount the amps right side up if you wanted... I've thought about that.. but this setup works fine for me. I've never had a problem with overheating, (where the amp shuts down while driving) Link to comment Share on other sites More sharing options...
merlin390 Posted April 5, 2005 Report Share Posted April 5, 2005 mine is the same way, upside down on the rear deck. Never have had a problem with heat. Remove the rear speakers let the bass come through. I just stuck my factory grills back in place minuse the speakers. Link to comment Share on other sites More sharing options...
Guest Guest_Helmut Ranff_* Posted April 5, 2005 Report Share Posted April 5, 2005 Upside down is fine especially with rear speakers removed. Nice wires Kevin Link to comment Share on other sites More sharing options...
AnthonyR Posted April 5, 2005 Report Share Posted April 5, 2005 I'll find the pics later today, but I took the spare wheel out and made an amp rack for my two amps down there under a plexiglass cover. Link to comment Share on other sites More sharing options...
javadoc Posted April 5, 2005 Author Report Share Posted April 5, 2005 I'll find the pics later today, but I took the spare wheel out and made an amp rack for my two amps down there under a plexiglass cover.←Thanks a bunch Anthony. I think I'd like the amps down there the best. I thought of a kind of double-decker rack, if the amps would fit in the confines of a full-size (16") spare, but I dunno on that point, since I'm still in the planning stage. It'd be the more stealth setup, imo.Hmmm, removing rear speakers? What about rear seat passengers? Do they just get sound from the door speakers then? Link to comment Share on other sites More sharing options...
theunderlord Posted April 5, 2005 Report Share Posted April 5, 2005 Hmmm, removing rear speakers? What about rear seat passengers? Do they just get sound from the door speakers then?←yeah, pretty much.. the rear deck speakers are like 8" 2 way woofers, so if you have a sub, they're pointless. the rear door speakers are well enough to provide your rear passengers with sound.. Link to comment Share on other sites More sharing options...
javadoc Posted April 5, 2005 Author Report Share Posted April 5, 2005 yeah, pretty much.. the rear deck speakers are like 8" 2 way woofers, so if you have a sub, they're pointless. the rear door speakers are well enough to provide your rear passengers with sound..←Well, my little audiophiles may get testy if the imaging sounds funky on their 'Radio Disney' CDs, so I have to be sure the sound didn't deteriorate back there. There'd be Hell to pay! :) Link to comment Share on other sites More sharing options...
theunderlord Posted April 5, 2005 Report Share Posted April 5, 2005 Well, my little audiophiles may get testy if the imaging sounds funky on their 'Radio Disney' CDs, so I have to be sure the sound didn't deteriorate back there. There'd be Hell to pay! ←hahaha, just put in a nice 12 W7, and make them FEEL the disney! Link to comment Share on other sites More sharing options...
javadoc Posted April 5, 2005 Author Report Share Posted April 5, 2005 Nah, I have two 8" JL Audios. They're plenty for me. Link to comment Share on other sites More sharing options...
