ezquipula1 Posted April 24, 2007 Report Share Posted April 24, 2007 thanks art Link to comment Share on other sites More sharing options...
BlackWolf Posted April 25, 2007 Report Share Posted April 25, 2007 tomedkaz wrote on Tue, 24 April 2007 17:42I love how clean yoru installations are...very very nice. SO when should we expect to see a workign product? Thanks Tommy, the system must work before next Saturday, I wrote some more info here with couple pictures: http://s40concepts.net/forum/index.php?t=msg&th=10591&am p;rid=1273&S=72fb14d451a72bc2671b1d46f07f9de3&pl_vie w=&start=15#msg_132130 Link to comment Share on other sites More sharing options...
pac Posted May 5, 2007 Report Share Posted May 5, 2007 What's the best way to cut these aluminum pipes? Any particular tool?Is there a source that most recommend or is it just finding one on eBay?-thanks! Link to comment Share on other sites More sharing options...
m4gician1568908566 Posted May 6, 2007 Report Share Posted May 6, 2007 you can use a hacksaw or handsaw...i've done it, just be careful of cutting yourself. Link to comment Share on other sites More sharing options...
vv086 Posted May 7, 2007 Report Share Posted May 7, 2007 isn't the idea of a hacksaw going to be a you know what to cut with. Maybe a metal circular blade would be better and cleaner, just adding my two sense. Regardless i ordered the metal pipe and couplers off ebay and need to get it installed. I got the bov attached to the old rubber tubing so i will need to weld a small 1inch pipe off the middle, hopefully it won't be expensive at a welding,muffler shop. Also, Tom, was the measurements stated earlier a good fit or did you measure yours seperately? I don't want to make and accident and cut it too short. Link to comment Share on other sites More sharing options...
BlackWolf Posted May 7, 2007 Report Share Posted May 7, 2007 If the welding is to expensive you can do it like i did with my BOV, just make sure the pipe end touches the intercooler and make a 30mm hole where the BOV comes slide the silicone T till over that hole so you can see it inside the small side on the T piece, this way you still have strong pipe like the others without BOV and the length is same.I saw it with handsaw, my tip is just measure and saw it couple mm longer and chek if it fits, repeat sawing till it fits perfectly, when you try to fit use the couplers to make sure everything fits together. And than like I told you above to make the hole for BOV install it to the T-piece and look for best position so you can mark the hole for BOV on the pipe.This is how my BOV is installed: I think it is cheaper than welding. Link to comment Share on other sites More sharing options...
BlackWolf Posted May 17, 2007 Report Share Posted May 17, 2007 Hey guys, if someone still want a U bend pipe, same guy where i got my pipe from on eBay offers 2 more, $19 for each.http://cgi.ebay.com/ebaymotors/2-5-2-5-inch-Turbo-Intercoole r-U-Bend-180-Degree-Pipe_W0QQitemZ270119350997QQihZ017QQcate goryZ6763QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItemhttp://cgi.ebay.com/ebaymotors/2-5-2-5-inch-Turbo-Intercoole r-U-Bend-180-Degree-Pipe_W0QQitemZ270120873059QQihZ017QQcate goryZ6763QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem Link to comment Share on other sites More sharing options...
m4gician1568908566 Posted May 18, 2007 Report Share Posted May 18, 2007 he's the same guy I picked mine up from, actually I just finished wrapping and spraying mine, leaving it to dry/cure under the hood for now. Link to comment Share on other sites More sharing options...
