theForgottenone Posted January 17, 2007 Report Share Posted January 17, 2007 You don't need two hump silicon coupler. Just one for the IC to TB side. The other one can use straight coupler. Link to comment Share on other sites More sharing options...
tomedkaz1568908563 Posted January 17, 2007 Author Report Share Posted January 17, 2007 xcites40 wrote on Wed, 17 January 2007 13:10You don't need two hump silicon coupler. Just one for the IC to TB side. The other one can use straight coupler.i bought two hump coz they look hotter... Link to comment Share on other sites More sharing options...
BlackWolf Posted January 17, 2007 Report Share Posted January 17, 2007 I bought two humps and one straight as spare. My biggest issue is the place for dump valve and bolt for water injection nozzle these things need to be welded. From what I understood this is the best place for a dump valve (close to throttle body) Link to comment Share on other sites More sharing options...
BlackWolf Posted January 17, 2007 Report Share Posted January 17, 2007 Here 2 another 180 degree aluminum pipes, it is not polished.on Ebay 3 availableon Ebay 1 available Both items from same seller, you could ask him for a group buy. Link to comment Share on other sites More sharing options...
tomedkaz1568908563 Posted January 17, 2007 Author Report Share Posted January 17, 2007 BlackWolf wrote on Wed, 17 January 2007 15:49Here 2 another 180 degree aluminum pipes, it is not polished.on Ebay 3 availableon Ebay 1 available Both items from same seller, you could ask him for a group buy. i like the polished one betteronce again man, good find Link to comment Share on other sites More sharing options...
mynessas40 Posted January 18, 2007 Report Share Posted January 18, 2007 nm Link to comment Share on other sites More sharing options...
Gustavo Posted January 18, 2007 Report Share Posted January 18, 2007 did he email you back tommy?? Link to comment Share on other sites More sharing options...
mynessas40 Posted January 18, 2007 Report Share Posted January 18, 2007 I already got a pipe, so I'm out of the group buy. Got everything I needTotalT Bolt Clamps $9.983" to 2.5" Reducer Coupling including 2 clamps (I have the Autotech IC, so it's a 3" outlet) $10.902.5" Hump Hose $16.99U-Bend Pipe $29.99Total $67.86 Link to comment Share on other sites More sharing options...
tomedkaz1568908563 Posted January 18, 2007 Author Report Share Posted January 18, 2007 Gustavo wrote on Thu, 18 January 2007 02:00did he email you back tommy??nope Link to comment Share on other sites More sharing options...
FluidGroove Posted January 18, 2007 Report Share Posted January 18, 2007 asian01 wrote on Thu, 18 January 2007 04:06I already got a pipe, so I'm out of the group buy. Got everything I needTotalT Bolt Clamps $9.983" to 2.5" Reducer Coupling including 2 clamps (I have the Autotech IC, so it's a 3" outlet) $10.902.5" Hump Hose $16.99U-Bend Pipe $29.99Total $67.86could be $57, you dont really need the t bolt clampsive found the oem clamps work fairly well and have not poped off even under 22 psi Link to comment Share on other sites More sharing options...
theForgottenone Posted January 18, 2007 Report Share Posted January 18, 2007 FluidGroove wrote on Thu, 18 January 2007 11:36asian01 wrote on Thu, 18 January 2007 04:06I already got a pipe, so I'm out of the group buy. Got everything I needTotalT Bolt Clamps $9.983" to 2.5" Reducer Coupling including 2 clamps (I have the Autotech IC, so it's a 3" outlet) $10.902.5" Hump Hose $16.99U-Bend Pipe $29.99Total $67.86could be $57, you dont really need the t bolt clampsive found the oem clamps work fairly well and have not poped off even under 22 psiThat's your choice. Wider bandwidth helps in distribution of total radial clamping pressure more uniformly and equally than narrow width or wire clamp S.S. Band T-Bolt imparts corrosion resistant Quality and advantage of re-use and failproofness after use.T-Bolt Clamps provide higher tensile strength, durability, and corrosion resistance than typical worm gear clampsThere is no comparison between OEM worm clamp and T-bolt. In addition, they don't damage the silicone couple as the worm clamp teeth will bite in and leave the permanent mark. Link to comment Share on other sites More sharing options...
BlackWolf Posted January 19, 2007 Report Share Posted January 19, 2007 I couldn't agree more with xcites40, and it looks better too Link to comment Share on other sites More sharing options...
GerBeGurGya Posted January 19, 2007 Report Share Posted January 19, 2007 Does it mean that the GB is off. Link to comment Share on other sites More sharing options...
cs40racing Posted January 19, 2007 Report Share Posted January 19, 2007 I'm meeting with my fabricator tomorrow, will ask him for a quote on this pipe... Link to comment Share on other sites More sharing options...
Gustavo Posted January 19, 2007 Report Share Posted January 19, 2007 will you provide free shipping I'm amuzing Tommy was going to do free shipping because of his job. (correct me if im wrong Tommy) Link to comment Share on other sites More sharing options...
