kenk Posted March 30, 2005 Report Share Posted March 30, 2005 got mine open fine, its hermetically sealed, used a dremmel, theres no way in without cutting. Sealed it up with hot glue. Been fine for over a year. Link to comment Share on other sites More sharing options...
zazzn Posted March 31, 2005 Report Share Posted March 31, 2005 so guys it's just a loose soldered connection that's causing all the headaches? Link to comment Share on other sites More sharing options...
Modus Posted May 24, 2006 Report Share Posted May 24, 2006 I really need to investigate with more time with mine. I didn't see any cracks. It's all conformally coated. You can open it with out cutting, you have to press the holding clips in the opposite direction, i used a small wratchet socket with a hammer to do that. The cover then popps off with minimal force.I did take a picture of it. however again i'm hard pressed to find these cracks on my own. I proberly won't get it repaired till I really need a new one when i'm done with it. is that the connector on the right side? where i should be looking for. i'm guessing these are hair line cracks?does the circuit card come out of this housing?thanksDrew Link to comment Share on other sites More sharing options...
gdizzle Posted August 26, 2007 Report Share Posted August 26, 2007 Bumping this topic. Opened up a bad ABS module and this what I found. I didn't just find cracked solder on the two power prongs, but also on the data connector, 9 pins were cracked on this side and the two power prongs were as well. I'll be doing a write up on the repair, but these pics will show you what to look for. Link to comment Share on other sites More sharing options...
