Howto: Take Off Top Dash Cover
Serge
I am talking about taking the wole dash apart not just the cover.  I have creeks in the actual dash.
Tbone
That's a big project. I suggest just finding the trouble spots and using epoxy to glue the heck out of them so they don't move. That's my plan :)
  • Replies 40
Step 7: With the glove box out, unbolt the four 10mm bolts holding the airbag in.
One of the nice aspects of the 850 is that the passenger side airbag is held in with four 10mm bolts. When I took my dash cover off my S70 the first time, I found two 10mm bolts and one stud bolt. :angry: Once I got the stud bolt out, I replaced it with a normal 10mm bolt.
Great write up, LiquidKernel!
  • 3 months later...
Well, it would seem the S70 is a slightly different beast. I'm trying to figure out how one disconnects the airbag... Heres a few pics.
One more thing. The center vent cover needs to be removed like in the Bay 13 writeup, but with the S70 there are 2 25 torx and they are on the bottom (in yellow)
Just if you asked this 5 days ago, we would have been able to snap some shots of Kevin's dash and airbag removal :)
There is a sticker pointing to the negative ground on the airbag, you will need to remove that CAREFULLY so you don't lose one of the nuts (2 nuts clamping the ground to the bolt). Then, there should be a connector (I think it's in the picture you posted) that just unplug and then you will be able to lift out the entire dash (airbag included).
I'm not seeing any tag or sticker pointing to a ground. I did take out the 3 10mm bolts that were going into the top of the dashpad. For the life of me though I can't seem to figure the airbag lead is cliped on though.
I did, er..do, have the negative lead on the battery unhooked. (no catastrophic airbag inflation, thank you)
Well, I got the airbag disconnect figured out, and I just went for a test drive...
absolutely gold. The rattling that I would get while driving down the freeway is gone. I can actually drive with the radio off and not be annoyed to hell. Serge, thanks so much for the write-up.
Oh, one suggestion. To avoid downtime, I used velcro that has an adhesive backing. You can find it at most craft or fabric stores.
  • 2 weeks later...
Awesome! I'm super glad I could help others.
I might do the velcro thing today, but it depends. Good to hear others have having results with it!
