Chopper Posted April 8, 2004 Report Share Posted April 8, 2004 19t...what sort of chip setup are you running? Link to comment Share on other sites More sharing options...
Boost Addicted Posted April 8, 2004 Author Report Share Posted April 8, 2004 Bill just did a Upsolute upgrade for me.Update: Just was driving normal and check engine lite came on. Checked the code it was P0171Lean1. Cleared it, boost immediatly came back for 2 floorings (2 min) lost it again. At least I got to floor it past the kid in a new evo. Hooked up a MBC (restrictor style) I can tune it back to normal boost, 12 - 14 psi. but boost comes in slower? Should I just leave it like that? What's the lean code about? I have 2 week old o2 sensors and Race cat. Link to comment Share on other sites More sharing options...
Chopper Posted April 9, 2004 Report Share Posted April 9, 2004 Hooked up a MBC (restrictor style) I can tune it back to normal boost, 12 - 14 psi. but boost comes in slower? Should I just leave it like that? What's the lean code about? I have 2 week old o2 sensors and Race cat.The lean coat means your car is not adding enough fuel for the amount of air. This makes the car run hot, and generally is not great for the life of the engine. If the code comes back, worry about it. This is probably a chip map issue. In this case you will probably have to go through another cycle of ECU tuning with Bill (IE dyno again, send him the wideband graphs). This should get your fuel patterns fine tuned.When you do a lot of work, sometimes fine tuning is required. No bad reflection on Bill. No two cars run exactly the same. Link to comment Share on other sites More sharing options...
Boost Addicted Posted April 9, 2004 Author Report Share Posted April 9, 2004 Things is, my wot O2s are super rich. 1.10. My egr is blocked, could that have anything to do with it?Tried pulling the ECU fuse overnight, no change. Link to comment Share on other sites More sharing options...
Chopper Posted April 12, 2004 Report Share Posted April 12, 2004 EGR should only be on when the car is cold. Link to comment Share on other sites More sharing options...
