vulvas40t41568908561 Posted December 14, 2010 Report Share Posted December 14, 2010 So its this turbo or with tial turbine side? Which a/r size will you choose for turbine (0.63a/r or 0.82a/r)? http://www.turbobygarrett.com/turbobygarrett/catelog/Turboch argers/GT30/GTX3076R_803713_1.htm Link to comment Share on other sites More sharing options...
arrtchiu Posted December 14, 2010 Report Share Posted December 14, 2010 vulvas40t4 wrote on Tue, 14 December 2010 13:39So its this turbo or with tial turbine side? Which a/r size will you choose for turbine (0.63a/r or 0.82a/r)? http://www.turbobygarrett.com/turbobygarrett/catelog/Turboch argers/GT30/GTX3076R_803713_1.htmSame core as on that link, but I believe he is using the same turbine housing, Tial V-Band .63 A/R , and same compressor housing Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted December 14, 2010 Report Share Posted December 14, 2010 arrtchiu wrote on Tue, 14 December 2010 07:45vulvas40t4 wrote on Tue, 14 December 2010 13:39So its this turbo or with tial turbine side? Which a/r size will you choose for turbine (0.63a/r or 0.82a/r)? http://www.turbobygarrett.com/turbobygarrett/catelog/Turboch argers/GT30/GTX3076R_803713_1.htmSame core as on that link, but I believe he is using the same turbine housing, Tial V-Band .63 A/R , and same compressor housing Yes turbine side fits directly to that new core and also compressor housing needs to be changed because bigger compressor wheel. Tcode what fuel did you use when dynoing? What RON? Link to comment Share on other sites More sharing options...
tcode1568908558 Posted December 14, 2010 Author Report Share Posted December 14, 2010 vulvas40t4 wrote on Tue, 14 December 2010 06:48Yes turbine side fits directly to that new core and also compressor housing needs to be changed because bigger compressor wheel. Tcode what fuel did you use when dynoing? What RON?That's true, I'll keep turbine housing only. I always run on a 100 octane gas pump fuel. There's no point using racing fuel or additives on a DD car. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted December 15, 2010 Report Share Posted December 15, 2010 Tcode here is GT3071/GT3076/GT3582 turbos with 0.63a/r turbine side in lancer evo 8 in same dyno and same setup. You see here that GT3076 is not that much better than GT3071 because it has same turbine side which is now bottle neck. Also much slower spool. When you see GT3582 which has bigger turbine side it flow much better and torque does not spike that badly. http://i119.photobucket.com/albums/o143/VulvaS40T4/garretttu rbocompare.jpg Link to comment Share on other sites More sharing options...
tcode1568908558 Posted December 16, 2010 Author Report Share Posted December 16, 2010 That evo 8 must have some serious issues, I never had torque spikes like that, ever. It might be because of too restrictive exhaust, exhaust manifold, cams, WG or whatever, and that's why it doesn't have benefit of the GT3076 turbo. Even with GT35 those figures doesn't look healthy and right to me. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted December 17, 2010 Report Share Posted December 17, 2010 Lets hope your right. If you had measured that manifolt pressure we would know more in how maxed up that 0.63a/r turbine is.Still in that picture you see that gt3071 vs gt3076 produces only 27hp more and spools 500rpm later and difference in those setups is only that bigger compressor wheel. Then much bigger gt3582 makes 58hp more than gt3071 and spools same as gt3076 and in gt3582 there is bigger compressor and turbine wheel, same turbine a/r in all.Shape of curves also points out that in evo gt3071 is fully maxed out and also gt3076 seems to be spiky in torque and gt3582 could have made more. Those red and blue lines are in different boost so you can see when turbo starts to be not so efficient any more. I think that you maxed out that gt3071 in your car and that turbo was in good balance betwheen compressor and turbine side. Now i would have chosen also bigger turbine a/r if you choose gt3076, because turbine wheel size is same in both. Buy 0.82a/r housing so you can really push that bigger compressor. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted December 17, 2010 Author Report Share Posted December 17, 2010 You are worried too much , anyway I really appreciate your suggestions. Btw. I'm getting GTX 3076, not old GT. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted January 29, 2011 Author Report Share Posted January 29, 2011 Another dyno session, 532HP at 7000 rpm and still having lot's of power after .http://www.youtube.com/watch?v=9cvP7SKGs2QYes, it's quite "warm" there Link to comment Share on other sites More sharing options...
tcode1568908558 Posted January 29, 2011 Author Report Share Posted January 29, 2011 And one more 100-200 attempt. Went not so well, it's cold outside and tires slips too much .http://www.youtube.com/watch?v=O-5VUe1OmvQ Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted January 29, 2011 Report Share Posted January 29, 2011 Your a pinoeer sir Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted January 30, 2011 Report Share Posted January 30, 2011 Has your new gtx3076 arrived? Link to comment Share on other sites More sharing options...
tcode1568908558 Posted January 30, 2011 Author Report Share Posted January 30, 2011 Your a pinoeer sirThank you sir .Has your new gtx3076 arrived?Nope, still didn't get it. Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted February 5, 2011 Report Share Posted February 5, 2011 Friend of yours???My link Link to comment Share on other sites More sharing options...
tcode1568908558 Posted February 10, 2011 Author Report Share Posted February 10, 2011 Friend of yours???My linkYeah, I know that guy, although 900HP is planned power once it will be finished. He's at 500bhp mark at the moment. Still very impressive project, even with 500hp "only" he's faster than Tesla or BMW M6 . Link to comment Share on other sites More sharing options...
