tcode1568908558 Posted February 21, 2010 Author Report Share Posted February 21, 2010 Link to comment Share on other sites More sharing options...
benisohh Posted February 21, 2010 Report Share Posted February 21, 2010 tcode wrote on Sun, 21 February 2010 06:37pure sex. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted February 22, 2010 Author Report Share Posted February 22, 2010 Thanks . I need a few more bits before starting the forged engine build. Link to comment Share on other sites More sharing options...
Sute1568908560 Posted February 22, 2010 Report Share Posted February 22, 2010 Which cams are you planning to put in? Pretty mild on the exhaust side, I guess? No valve pockets on the exhaust side. I have 263 degrees measured @ 1,0mm clearance (12,3mm lift) on the intake and 252 degrees @ 1,0 clearance (11,8mm lift) on the exhaust. With 0 clearance those are nearly 300 / 290 degrees... Link to comment Share on other sites More sharing options...
Danilis Posted February 22, 2010 Report Share Posted February 22, 2010 Very impressive numbers so far! i wish for your new engine to pass over your targets and expectations. it's impressive the good breathing from the oem head. If i remember correct yours was not ported and it had just a NA inlet cam. i think 450hp and 500nm, was limit for this engine and turbine as well. Link to comment Share on other sites More sharing options...
GerBeGurGya Posted February 23, 2010 Report Share Posted February 23, 2010 What's the compression ratio with these? Link to comment Share on other sites More sharing options...
benisohh Posted February 23, 2010 Report Share Posted February 23, 2010 GerBeGurGya wrote on Mon, 22 February 2010 17:19What's the compression ratio with these?x2? Link to comment Share on other sites More sharing options...
tcode1568908558 Posted February 23, 2010 Author Report Share Posted February 23, 2010 Sute wrote on Mon, 22 February 2010 20:15Which cams are you planning to put in? Pretty mild on the exhaust side, I guess? No valve pockets on the exhaust side. I have 263 degrees measured @ 1,0mm clearance (12,3mm lift) on the intake and 252 degrees @ 1,0 clearance (11,8mm lift) on the exhaust. With 0 clearance those are nearly 300 / 290 degrees... I'll keep n/a cams for a while, can't do anything with the head at the moment. Those cams you're having looks wild . I'm wondering how will your idle look like. Where did you get those cams and how much? Link to comment Share on other sites More sharing options...
tcode1568908558 Posted February 23, 2010 Author Report Share Posted February 23, 2010 Danilis wrote on Tue, 23 February 2010 00:30Very impressive numbers so far! i wish for your new engine to pass over your targets and expectations. it's impressive the good breathing from the oem head. If i remember correct yours was not ported and it had just a NA inlet cam. i think 450hp and 500nm, was limit for this engine and turbine as well.Thank you .The OEM head was forced for a good breathing (2,3 bar of boost ). Yes, you are absolutely right, turbo was squeezed to the max too . Link to comment Share on other sites More sharing options...
tcode1568908558 Posted February 23, 2010 Author Report Share Posted February 23, 2010 GerBeGurGya wrote on Tue, 23 February 2010 02:19What's the compression ratio with these?Same as a stock T4 has, 8.5:1. Link to comment Share on other sites More sharing options...
Danilis Posted February 23, 2010 Report Share Posted February 23, 2010 tcode wrote on Tue, 23 February 2010 11:37GerBeGurGya wrote on Tue, 23 February 2010 02:19What's the compression ratio with these?Same as a stock T4 has, 8.5:1. I would advice a bit more of compression (~9-9,3) in order to run lower boost levels and be in a better efficiency places of the compressor's maps. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted February 23, 2010 Author Report Share Posted February 23, 2010 Depends of the turbocharger choice. And how it seems I won't be long on GT30 . Link to comment Share on other sites More sharing options...
Sute1568908560 Posted February 23, 2010 Report Share Posted February 23, 2010 tcode wrote on Tue, 23 February 2010 01:33Sute wrote on Mon, 22 February 2010 20:15Which cams are you planning to put in? Pretty mild on the exhaust side, I guess? No valve pockets on the exhaust side. I have 263 degrees measured @ 1,0mm clearance (12,3mm lift) on the intake and 252 degrees @ 1,0 clearance (11,8mm lift) on the exhaust. With 0 clearance those are nearly 300 / 290 degrees... I'll keep n/a cams for a while, can't do anything with the head at the moment. Those cams you're having looks wild . I'm wondering how will your idle look like. Where did you get those cams and how much?They were first welded to get more material on noses of the cam and then grinded to the desired shape and finally nitrated in order to make the noses last. The base circle is as in stock cam. They are originally Autotech cams, 10,5 / 260 degrees...The idle depends a lot from the cam setup. For "smooth" idle, the intake will be delayed and exhaust advanced and for race set up vice versa. It is for sure the idle will suffer, but I hope I pass the smog test.. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted February 23, 2010 Author Report Share Posted February 23, 2010 Cool , I hope you will pass the smog test too. With a good tune it should be possible. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted February 28, 2010 Author Report Share Posted February 28, 2010 Finally finished big bore TB .Bore and plate is 62mm. Sealing is perfect . Link to comment Share on other sites More sharing options...
