Asinine Posted April 18, 2005 Report Share Posted April 18, 2005 So, spring has sprung up here in the arctic tundra you all know as Canada, and my new car need a wax job.But before i do that, there are some ston chips around the grill of my Black 850 and i was wondering what (if any product) you'd all recommend that i use to fill those in without re-painting the whole hood.This Turtle Wax Color Cure comes with a little lipstick thing of paint filler or some such crap that you are supposed to use to fill any chips. If i had a car that wasn't black i wouldn't think of using it, but color matching i hope won't be an issue.Does anyone have any comments/concerns about this product or can recommend something else that will work better.While i'm asking.. what would be the wax/polish of choice you use!? Link to comment Share on other sites More sharing options...
exexpat Posted April 18, 2005 Report Share Posted April 18, 2005 Doesn't work on my white car. I touch up, then wait an hour and use Maguiar's #1, followed by #2, then Gold Class wax. Leaves it wet and creamy. Link to comment Share on other sites More sharing options...
billr99 Posted April 18, 2005 Report Share Posted April 18, 2005 So, spring has sprung up here in the arctic tundra you all know as Canada, and my new car need a wax job.But before i do that, there are some ston chips around the grill of my Black 850 and i was wondering what (if any product) you'd all recommend that i use to fill those in without re-painting the whole hood.This Turtle Wax Color Cure comes with a little lipstick thing of paint filler or some such crap that you are supposed to use to fill any chips. If i had a car that wasn't black i wouldn't think of using it, but color matching i hope won't be an issue.Does anyone have any comments/concerns about this product or can recommend something else that will work better.While i'm asking.. what would be the wax/polish of choice you use!?←I don't know if you get the sandblasting damage down in Waterloo like we do here in the North Bay area, but I tried some of that Turtle Wax coloured wax stuff on a black SAAB I had once. It worked initially, but over a fairly short time it washed out and made the nose of the car look almost worse. We also used it on my son's black Jetta TDI with the same result. I took a look at the front of my red R over the weekend and I think I'm going to be forced to wet sand and then do a light re-spray with some more wet sanding to bring mine back. But I also don't have to contend with a clearcoat since the red (code 603??) does not use it. So I've had good luck before with this type of touch-up using Dupont Centuri paint and an airbrush. I get an excellent match and its easy to work. Once I get done with the wet sanding I go thru the Meguiar's polishing compounds and a coating of Techwax and am good to go. Next weekend's project, I guess, as long as the weather holds up.Cheers, Link to comment Share on other sites More sharing options...
850Boyo Posted April 18, 2005 Report Share Posted April 18, 2005 all i use is the turtle wax color cure, it does actually darken the paints color but if the chips are to big then the chipstick doesnt stay inside the chips, i do recommend using the wax for making the color of your car deeper and.......well...more colorful. Link to comment Share on other sites More sharing options...
