bogelo Posted April 26, 2005 Report Share Posted April 26, 2005 What could be the problem? Speed sensor? But the RPM and MPH are working. Only the mileage doesn't work. TIA Link to comment Share on other sites More sharing options...
WhiteT5 Posted April 26, 2005 Report Share Posted April 26, 2005 Your odometer gear is broken. Happens to everyone. I believe IPD sells a stronger replacement gear. Link to comment Share on other sites More sharing options...
theunderlord Posted April 26, 2005 Report Share Posted April 26, 2005 Your odometer gear is broken. Happens to everyone. I believe IPD sells a stronger replacement gear.←Ding ding ding! Link to comment Share on other sites More sharing options...
Chris_R Posted April 26, 2005 Report Share Posted April 26, 2005 Ok, I replaced my odo gear... Still no workie. Now what? Link to comment Share on other sites More sharing options...
Bay13 Posted April 26, 2005 Report Share Posted April 26, 2005 Ok, I replaced my odo gear... Still no workie. Now what?Did you actually do the work? Where did you get the replacement gear from? Did you find the broken gear when you took it apart?http://www.volvospeed.com/vs_forum/index.php?showtopic=8398 Link to comment Share on other sites More sharing options...
Chris_R Posted April 26, 2005 Report Share Posted April 26, 2005 Did you actually do the work? Where did you get the replacement gear from? Did you find the broken gear when you took it apart?http://www.volvospeed.com/vs_forum/index.php?showtopic=8398←Yessir, I did it myself. Gear was toast. I got the gear from my indie Volvo shop. I may have to pull it apart again and make sure I didn't put it in backwards or something stupid. It may have broken the new gear for all I know. The mileage is a little different than it was, but I moved some things while I had it apart. The reset worked... once. Link to comment Share on other sites More sharing options...
Bay13 Posted April 26, 2005 Report Share Posted April 26, 2005 I'd tear into it again. Use the link above and you can get the gears from the listed link . Odometergears dot com or something like that. Link to comment Share on other sites More sharing options...
Chris_R Posted April 26, 2005 Report Share Posted April 26, 2005 Just happy that it runs again for now. See: http://volvospeed.com/vs_forum/index.php?s...pic=20586&st=30-Chris Link to comment Share on other sites More sharing options...
Bay13 Posted April 26, 2005 Report Share Posted April 26, 2005 By the way nice work! Link to comment Share on other sites More sharing options...
Chris_R Posted April 27, 2005 Report Share Posted April 27, 2005 *blush*That quote might just have to go in my sig. :D Link to comment Share on other sites More sharing options...
