S40TUNER Posted June 2, 2015 Report Share Posted June 2, 2015 I have a 2000 Volvo s40 1.9 T is that a vacuum leak for so long I'm not sure what the normal idle RPM are supposed to be if anybody can inform me It would be greatly appreciated as are doing right now its 600 r_p_m seems kind low but I'm not sure insight would be appreciated Link to comment Share on other sites More sharing options...
TEEKAY Posted June 2, 2015 Report Share Posted June 2, 2015 I believe 750 is normal idle. edit: fwiw on startup i might get up to 1100 sometimes but it always settles down. Link to comment Share on other sites More sharing options...
Phixion Posted June 2, 2015 Report Share Posted June 2, 2015 I concur on 750'ish being the warm engine idle. Mine would initially fire up at 1500, then lower to about 1100 after say 15 - 20 seconds. Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted June 2, 2015 Report Share Posted June 2, 2015 OT idle is 750 rpm, cold start is 1100 rpm to help bring the motor up to temp, you'll notice your auto box runs the RPMs higher before shifting when cold to also help with warming up. Link to comment Share on other sites More sharing options...
S40TUNER Posted June 4, 2015 Author Report Share Posted June 4, 2015 thank you status update its currently are you doing 400 rpms and when I hit the gas well as a neutral and hurry up and let off it stalls it has a new IAC valve MAP sensor mass air flow sensor can anybody help me figure out what the problem could be I had it fixed for a while it just started again recently any suggestions on what I should replace next I'm running out of sensors to replace like I said new IAC, MAF, MAP, COILS, WIRES, PLUGS, UPPER O2, water temp, thermostat,TCV and soon the IAT so please any suggestions Link to comment Share on other sites More sharing options...
theForgottenone Posted June 4, 2015 Report Share Posted June 4, 2015 is the rubber hose from the intercooler to the IAC doesn't have any leak? Link to comment Share on other sites More sharing options...
