Tommy B. Posted June 14, 2015 Report Share Posted June 14, 2015 Saw an old tread about tire pressure for 17'' and a member said Volvo recommends 39PSI front and 36PSI rear on full load but he put 38PSI all around... Why inside my door it says 32PSI front 29PSI rear then ?? Where did he find that 39-36 psi reference ?http://www.30forty50...__1#entry152882 Link to comment Share on other sites More sharing options...
Tommy B. Posted June 14, 2015 Author Report Share Posted June 14, 2015 http://www.puretyre.co.uk/volvo-tyre-pressures/ Link to comment Share on other sites More sharing options...
Tommy B. Posted June 14, 2015 Author Report Share Posted June 14, 2015 after checking on mine i got 26 front and 25 rear... Now i know why i do less mileage Link to comment Share on other sites More sharing options...
theForgottenone Posted June 14, 2015 Report Share Posted June 14, 2015 I try to stay close to 35psi all around. Link to comment Share on other sites More sharing options...
TEEKAY Posted June 15, 2015 Report Share Posted June 15, 2015 Haven't checked mine since I got new wheels but will run 40 if that's not where its at right now. I always forget to check when they're cold and when I think to it's when they're hot.This pic was on the uk boards from a 2004 manual referencing the arcadias. Link to comment Share on other sites More sharing options...
Tommy B. Posted June 15, 2015 Author Report Share Posted June 15, 2015 I felt the difference in ride with 32 front 29 rear, will try 35 but should i go more in front than the rear or even all around? I drive alone or with my GF with nothing in the trunk Link to comment Share on other sites More sharing options...
Phixion Posted June 15, 2015 Report Share Posted June 15, 2015 The 32/29 is for the standard "15 wheels I believe... That's what my 40 said anyways. My now S60 with factory installed "17s say 36psi if I recall correctly... Like Xcites said though, I kept mine at 35psi all around regardless. Gotta figure out the right all around for these "17's... Link to comment Share on other sites More sharing options...
theForgottenone Posted June 15, 2015 Report Share Posted June 15, 2015 You can give less on the rear but with it won't make a big difference of a few small psi (2) vs the front. If you track it or plan to drag race it then optimal to keep it no more than 32psi.Daily driving, then 35psi is perfect. Link to comment Share on other sites More sharing options...
