s40speed Posted August 22, 2015 Report Share Posted August 22, 2015 Hi guys I was working on the car today and noticed the rad was rotting so what are simple proformance options for a 00 S40 radiator not an intercooler a coolant radiator any help is appreciated thank you Link to comment Share on other sites More sharing options...
Welditup Posted August 23, 2015 Report Share Posted August 23, 2015 Shop for the stock dimensions on your factory unit and find a aftermarket unit that matches. I wouldn't bother upgrading your radiator, spend the extra cash on your intercooler. Have a welder do up the end pipes and bungs for the sensors, shouldn't cost more that $100 at a shop if you have everything figured out for him welding it. Link to comment Share on other sites More sharing options...
1clean00 Posted August 24, 2015 Report Share Posted August 24, 2015 there isn't really need to upgrade. The stock units are fine, especially if this is on an otherwise stock vehicle. If you had a fully built engine and a large frame turbocharger i'd recommend upgrading, but for everyday driving the stock unit works. Link to comment Share on other sites More sharing options...
Phixion Posted August 25, 2015 Report Share Posted August 25, 2015 Just get a good quality OEM replacement. When I replaced the radiator on mine, I came to learn that at least for Ebay sellers, there's grades of products that they use... C grade is what you'll find on Ebay for cheap. B grade is like what you'd find at most auto parts retail stores, and A grade of course is best quality. I went with a B grade which was pretty cheap on the wallet, but bought from the seller directly in person, so essentially got a B grade for C grace cost. Worked out fine, and had no issues with it. Link to comment Share on other sites More sharing options...
s40speed Posted August 26, 2015 Author Report Share Posted August 26, 2015 Ok though when I do this I'm also hooking up my fmic any idea how to mount the stock rad without the stock intercooler on the car I'd rather use a stock radiator if I can figure out how to mount it ya know Link to comment Share on other sites More sharing options...
1clean00 Posted August 26, 2015 Report Share Posted August 26, 2015 You can simply use some washers in place of the intercooler mountings to fill the void. I put pieces of rubber vac line on the mounting bolts on my S60 to both space them out for mountings purpose, and to isolate any noise/vibration. And if you hadn't though about it, you may want one of these...http://www.snabb.us/99-02-weld-on-MAPIAT-bung_p_157.html that way you can mount the IAT sensor and the MAP sensor that are integral to the stock intercooler. You'd want them on the intercooler-throttle body pipe, roughly the same distance they are now away from the throttle body. Link to comment Share on other sites More sharing options...
s40speed Posted August 27, 2015 Author Report Share Posted August 27, 2015 Cool thanks but the maf is on the intake tube right off the air box the is that hose on the manifold right below the iac valve is that what they are talking about when they say maf My fault wasn't paying attention ignored the p I seen ma and assumed u were talking about the maf the map sensor is in the manifold on mine right beside the injectors does anybody sell any adaptor for the iac hose or does that have to be custom Idk what u call a highly modified engine but here's my mod list. Mototec cone filter,upgraded tcv,lightweight crank pulley, red injectors, throttle and intake spacer,mbc @15psi,breather catch can,aluminum intercooler tubing turbo to throttle body I think that's all on the car still to come fmic,14t turbo and tune,custom exhaust, ported and polished head and intake if they can do it, big bore throttle body, better wastegate and atmospheric bov, then I'll probably run at least 20psi so what do you think will the stock rad handle it Link to comment Share on other sites More sharing options...
1clean00 Posted August 27, 2015 Report Share Posted August 27, 2015 There are two map sensors, one leaving the intercooler, and one on the manifold. There is also an IAT sensor on the intercooler. Don't know why you're talking about the MAF at all, has nothing to do with the intercooler. You will though have to route a hose to the IAC valve, just need to weld a fitting on your interccooler piping and run a length of hose to the iac valve, otherwise it'll idle and run like stuff. Link to comment Share on other sites More sharing options...
s40speed Posted August 27, 2015 Author Report Share Posted August 27, 2015 Ok and I was not paying attention when I said maf that was my mistake lol so u know what's on the car and what's going to be on the car can the stock rad handle it or should I upgrade Link to comment Share on other sites More sharing options...
1clean00 Posted August 28, 2015 Report Share Posted August 28, 2015 The radiator is fine, you won't need to upgrade it for the power level you're making or will ever make. Unless you are planning on fully building the motor and dropping serious $$$ on a turbo and tuning. The stock radiator is going to be fine. If you're that concerned with cooling, replace the cooling system in its entirety and convert to evans waterless cooling... http://www.evanscooling.com/. Link to comment Share on other sites More sharing options...
s40speed Posted August 29, 2015 Author Report Share Posted August 29, 2015 Where's the second map sensor I took the stock intercooler off and all I found was the iat sensor and like I said all the tubing is aluminum and I didn't come across it when I did that either are u sure there's 2 and if so can you let me know where to find it thank you for all ur help this far it's nice to be able to ask someone with experience with these cars. They are strange creatures I wouldn't trade mine for nothing though Link to comment Share on other sites More sharing options...
TEEKAY Posted August 29, 2015 Report Share Posted August 29, 2015 I'll go take a pic for ya.MAP sensors in red. Link to comment Share on other sites More sharing options...
s40speed Posted August 30, 2015 Author Report Share Posted August 30, 2015 Ok thank u I looked and mine doesn't have the second map sensor just the iat sensor and the iac valve hose on the intercooler can anyone tell me why yours has it and mine doesn't I am very interested in knowing why it's a 2000 I don't know if that makes a difference and thanks for the pic very helpful Just want to be sure the blue is the iat sensor right Link to comment Share on other sites More sharing options...
s40speed Posted August 30, 2015 Author Report Share Posted August 30, 2015 How do u post a pic I'm using a phone Never mind I figured it out I'll put one up tonight and keep in mind that the stock intercooler has the plastic tanks removed cuz I'm scraping it k Link to comment Share on other sites More sharing options...
s40speed Posted August 31, 2015 Author Report Share Posted August 31, 2015 This is the top of the stock intercooler that was in my car as u see only has iat sensor and iac valve hose nipple can you tell me why yours is different Link to comment Share on other sites More sharing options...
