1clean00 Posted August 31, 2015 Report Share Posted August 31, 2015 Just looked at mine yesterday. The 00' only has the IAT and IAC on the intercooler. 01'+ got two map sensors. So basically on the intercooler you just need a boss for the IAT and a vac port for the IAC valve. I'd just measure that out and get some bulk silicone hose that is the same id. Link to comment Share on other sites More sharing options...
s40speed Posted September 6, 2015 Author Report Share Posted September 6, 2015 Ok thank you I got an off topic question I was having issues with a vacuum leak and as a result my turbo got extremely hot and basically welded it's self to the exhaust manifold any ideas for removing it without replacing every thing all suggestions welcome and thank you for all the help this far guys still trying to understand Volvo cars lol Link to comment Share on other sites More sharing options...
theForgottenone Posted September 8, 2015 Report Share Posted September 8, 2015 Maybe try soak it with some sort of nut blaster Link to comment Share on other sites More sharing options...
s40speed Posted September 8, 2015 Author Report Share Posted September 8, 2015 Ok cool any suggestions on what kind to use I've always used pb blaster but if there's something better then I'm willing to try it thank you Link to comment Share on other sites More sharing options...
TEEKAY Posted September 8, 2015 Report Share Posted September 8, 2015 Try and find aero kroil - aka Kroil. You can find it in a lot of farm equipment / tractor places. It is more expensive and worth EVERY penny. http://www.amazon.com/Kano-AeroKroil-Penetrating-Aerosol-13-Ounce/dp/B005XUIX24also when all else fails, hit it with the torch Link to comment Share on other sites More sharing options...
1clean00 Posted September 8, 2015 Report Share Posted September 8, 2015 have some new studs and nuts ready for the install. Link to comment Share on other sites More sharing options...
s40speed Posted September 9, 2015 Author Report Share Posted September 9, 2015 Ok thanks guys I'm just curious has any of y'all had this issue sometimes the vacuum leak fixes it self until I have to remove the intake manifold for something I got that down to a science I can have the manifold off in 10 minutes probably not a good thing that I've had to remove it so many times Link to comment Share on other sites More sharing options...
1clean00 Posted September 9, 2015 Report Share Posted September 9, 2015 Most notorious "hidden leaks." Brake booster hardline at the manifold, fitting becomes loose and doesn't hold hard line, may blow itself loose under hard boost, fine under vac or normal cruising. Also the IAC hose running to the intercooler, they become hard and brittle over time and can crack at the clamps and give false MAF codes, or otherwise rough running, idle issues and low boost across the board. Link to comment Share on other sites More sharing options...
s40speed Posted September 9, 2015 Author Report Share Posted September 9, 2015 Ok thanks I'm gonna replace the pcv system while it is tore apart still working on the head and how do you remove the studs from the manifold and turbo working on it now and having issues Link to comment Share on other sites More sharing options...
theForgottenone Posted September 9, 2015 Report Share Posted September 9, 2015 why you need to remove the studs from the manifold? Link to comment Share on other sites More sharing options...
s40speed Posted September 9, 2015 Author Report Share Posted September 9, 2015 Well I'm taking the head off to replace the little o rings where the spark plug screws in and being that I bought the car for 400$ I'm replacing everything along the way and am having a full polish done on the head and rebuilding it so I don't have to do this again anytime soon and I love the expression on people's faces when they get beat by a s40 ya know lol Link to comment Share on other sites More sharing options...
1clean00 Posted September 9, 2015 Report Share Posted September 9, 2015 3 angle valve job and match the intake runners is what i did on the T5. Really woke up the motor, smooth power and doesn't feel like it works as hard under heavy boost. Link to comment Share on other sites More sharing options...
Phixion Posted September 10, 2015 Report Share Posted September 10, 2015 I dunno, when my brake booster hardline blew from the manifold, it was not under boost. It was actually during coasting and deceleration on a down sloped freeway offramp thankfully. But if the hardline completely releases out of the manifold, the engine will stop rendering the car VERY difficult to maneuver or stop if any evasive action is needed... No power brakes or power steering. Link to comment Share on other sites More sharing options...
s40speed Posted September 11, 2015 Author Report Share Posted September 11, 2015 Yeah I thought about that and replaced it with silicone there is not much that's not silicone I replaced it all except the pcv lines with silicone that's y I gonna replace the pcv system and hope for the best Link to comment Share on other sites More sharing options...
