flyfishing31568908306 Posted August 24, 2015 Report Share Posted August 24, 2015 98 V70R i can feel cold air out of ac so i know thats working fine. the blower is not blowing under any setting including auto. fuses are fine. how can i jump the resistor to see if its that before diving into the blower motor? Link to comment Share on other sites More sharing options...
BEJinFBK Posted August 25, 2015 Report Share Posted August 25, 2015 98 V70R i can feel cold air out of ac so i know thats working fine. the blower is not blowing under any setting including auto. fuses are fine. how can i jump the resistor to see if its that before diving into the blower motor?To rule out everything except the motor,unplug it and feed it 12 volts. Link to comment Share on other sites More sharing options...
flyfishing31568908306 Posted August 25, 2015 Author Report Share Posted August 25, 2015 LolThat's what I don't know how to do. Where's the points I need to jump? What around there is 12v I can steal off of? Link to comment Share on other sites More sharing options...
BEJinFBK Posted August 26, 2015 Report Share Posted August 26, 2015 There's a battery under the hood.Got a fuse holder and some wire? Link to comment Share on other sites More sharing options...
flyfishing31568908306 Posted August 26, 2015 Author Report Share Posted August 26, 2015 LolWhere is the blower motor point I can touch into? Link to comment Share on other sites More sharing options...
BEJinFBK Posted August 26, 2015 Report Share Posted August 26, 2015 Here's what I've always done to check out a blower motor in any rig.Take it out. Inspect the squirrel cage and the duct it came out of andclean if needed. Make sure the cage spins freely. Check the motor shaft bearings for wiggle and end play. While keeping a good grip,apply voltage to the motor and confirm that it runs smoothly.Lubricate the bearings. I prefer TriFlow.There are only two terminals on the motor. Link to comment Share on other sites More sharing options...
