s40speed Posted September 12, 2015 Report Share Posted September 12, 2015 Hi guys I'm working on my car and realized the issue wasn't in the head it's the piston rings so my question is how do I go about pulling the engine I read somewhere u had to remove the torque converter be for unbolting the transmission is this true cuz it makes no sense to me since the torque converter is in the bell housing any information is awesome and where can I find h beam connecting rods and better than stock forged pistons if u have a link even better I want to do it up right ya know oh and rings and if the make better valves and such that is appreciated also so please help guys I'm used to Honda this is my first Volvo and they really are a new breed thank you Link to comment Share on other sites More sharing options...
theForgottenone Posted September 12, 2015 Report Share Posted September 12, 2015 Call them http://yhst-26451710505916.stores.yahoo.net/hcoroforvowh.htmlStock piston should be fine.Tell them Warren with the blue s40 sent you.You can try eBay as I remember couple people bought them very cheap China rods without any issue. I don't have exact link but seen thread over volvospeed forum. Link to comment Share on other sites More sharing options...
s40speed Posted September 12, 2015 Author Report Share Posted September 12, 2015 Link to comment Share on other sites More sharing options...
s40speed Posted September 13, 2015 Author Report Share Posted September 13, 2015 Ok has anyone else ever done this before and have any tips like can I drop the oil pan and disconnect the rods and pull the pistons or does the block have to come out Link to comment Share on other sites More sharing options...
s40speed Posted September 14, 2015 Author Report Share Posted September 14, 2015 Does anybody know where I can find a valve compressor tool or if a universal tool that will work on our engines thanks for any help Link to comment Share on other sites More sharing options...
theForgottenone Posted September 14, 2015 Report Share Posted September 14, 2015 Ok has anyone else ever done this before and have any tips like can I drop the oil pan and disconnect the rods and pull the pistons or does the block have to come out I don't think anyone ever try to do by the drop the oil pan only. Most likely you will have to take the block out. Link to comment Share on other sites More sharing options...
s40speed Posted September 16, 2015 Author Report Share Posted September 16, 2015 I don't think anyone ever try to do by the drop the oil pan only. Most likely you will have to take the block out.Ok thanks I was wondering about that I've seen it done with Ford's lol but Volvo is on a whole new level. Well at least I can paint the block and all make it look as good as she runs lol Link to comment Share on other sites More sharing options...
Phixion Posted September 16, 2015 Report Share Posted September 16, 2015 It's most likely going to require a complete engine pull. Tranny comes out with the engine of course, and then you can split the two from there. When I had an engine replacement on my S40 at the beginning of this year, the shop dropped the engine out from the bottom and put the "new" one in the same way. Link to comment Share on other sites More sharing options...
s40speed Posted September 21, 2015 Author Report Share Posted September 21, 2015 Ok can it be lifted out I don't have a lift doing it myself and my garage doesn't have clearance for a lift and can I unbolt the the tranny and just pull the block out or do they have to come out together Link to comment Share on other sites More sharing options...
theForgottenone Posted September 21, 2015 Report Share Posted September 21, 2015 you can unbolt the tranny Link to comment Share on other sites More sharing options...
s40speed Posted September 21, 2015 Author Report Share Posted September 21, 2015 Ok cool I have it tore down to just a block planning on lifting it out by hand so all I have to to is remove the transmission bolts and it will separate from the tranny right Link to comment Share on other sites More sharing options...
s40speed Posted September 25, 2015 Author Report Share Posted September 25, 2015 Ok guys I got a hold of vivaperformance they are hooking me up with every thing from the connecting rods to to valve springs and retainers and everything in between so my question is with a fully built motor like that what is the max boost I can run I'm hoping 30 to 35psi I understand that I need to do a trans swap and have it tuned for the added boost but what else do I need to do? Do I need bigger injectors I have red top ones now please help me out what other upgrades do I need to do to make this possible can a 14t turbo make that kind of boost not worried about$ I'm single no kids and 3 jobs any input appreciated Link to comment Share on other sites More sharing options...
theForgottenone Posted September 25, 2015 Report Share Posted September 25, 2015 You need someone can tune your car. That is the biggest issue of having bigger turbo. 14t won't do much beyond 250hp Link to comment Share on other sites More sharing options...
s40speed Posted September 25, 2015 Author Report Share Posted September 25, 2015 I'm not trying to go with a bigger turbo than a 14t just want to run the max boost I can I'm not looking for the turbo to do it all looking for any power I can get ya know Link to comment Share on other sites More sharing options...
