PLANT Posted October 26, 2015 Report Share Posted October 26, 2015 Hi all, I had my original top radiator hose replaced. Obviously coolant was replaced.Prior to this my temp gauge needle would be dead centre and seemed to get there very quickly on start up.(Unnoticeable) Now It slowly makes its way to the centre and seems to be a fraction to the right of middle? ie. 5 minutes of driving.Is this common and normal? Link to comment Share on other sites More sharing options...
1clean00 Posted October 26, 2015 Report Share Posted October 26, 2015 When they did the top hose and the coolant was the thermostat replaced? What temp thermostat is being used? Stock is 90C which is roughly 195F. Link to comment Share on other sites More sharing options...
catback Posted October 26, 2015 Report Share Posted October 26, 2015 And if the thermostat was replaced, was it with an OEM (Volvo) thermostat or aftermarket?There is a short list of items that MUST be factory (IMHO)ThermostatSpark plugsGas cap odds are that the new coolant hose allows for some improved flow/better cooling. I wouldn't stress over this. I'd be more worried if the temps were climbing. To the righ of center would indicate a lower temp to me.As long as you aren't getting a CEL with a temp lower than expected error, then I'd say all is good. Link to comment Share on other sites More sharing options...
PLANT Posted October 26, 2015 Author Report Share Posted October 26, 2015 Right of centre is higher temp for me...just a tiny bit....that it is not dead centre.The thermostat was not replaced this time but has been on previous services before hose replaced. Link to comment Share on other sites More sharing options...
TEEKAY Posted October 28, 2015 Report Share Posted October 28, 2015 Dead center usually happens ~194ish for me. Even up to 220 it's still dead center. Link to comment Share on other sites More sharing options...
1clean00 Posted October 28, 2015 Report Share Posted October 28, 2015 When i switched from a 90*C to 87*C thermostat in the summer and added a bottle of water wetter my temp stayed just under center. Toward the cool side. Link to comment Share on other sites More sharing options...
TEEKAY Posted October 28, 2015 Report Share Posted October 28, 2015 When i switched from a 90*C to 87*C thermostat in the summer and added a bottle of water wetter my temp stayed just under center. Toward the cool side. I ordered a 87 stat yesterday! Link to comment Share on other sites More sharing options...
1clean00 Posted October 28, 2015 Report Share Posted October 28, 2015 I ordered a 87 stat yesterday! Save it for Spring tune up if you want hot heat this winter! Link to comment Share on other sites More sharing options...
Phixion Posted October 28, 2015 Report Share Posted October 28, 2015 Dead center is where it should be at. I have good experience with this while utilizing an ECU read digital reading of the coolant... The needle will not begin moving off the center until somewhere between 225 and 228F... This is roughly 10 degrees HIGHER than the car should ever reach. 215F is the fan fan switch temp and I never ever saw my S40 get higher than this temp, even in horrid traffic in the middle of a 110F+ heatwave... If you can get your hands on a code scanner that displays live data, it should be able to let you see the ECU reported actual coolant temp. Link to comment Share on other sites More sharing options...
TEEKAY Posted October 30, 2015 Report Share Posted October 30, 2015 I stand corrected, I watched the temp / reader today. Dead center at 172. Link to comment Share on other sites More sharing options...
theForgottenone Posted October 30, 2015 Report Share Posted October 30, 2015 Mine is slightly under dead center. I used 87 c thermostat Link to comment Share on other sites More sharing options...
PLANT Posted November 1, 2015 Author Report Share Posted November 1, 2015 So a code reader should tell me exact temp? Link to comment Share on other sites More sharing options...
Phixion Posted November 2, 2015 Report Share Posted November 2, 2015 Well it should tell you what the ECU is reporting which should be fairly accurate temp wise. But it's a digital reading which gives a more clear picture than a gauge that doesn't move much. Link to comment Share on other sites More sharing options...
