VOLTA551568908589 Posted February 22, 2016 Report Share Posted February 22, 2016 so this is the new spot, eh? the V40 is still driving like it a champ at 210K.. trying to keep the outside clean but 14 year old paint tends to naturally die lol still mostly stock with a k&n, M.B.C at 12psi. i still love driving it. storage is perfect for skiing/ biking my only big problem i can think of is when starting the motor cold, there is a loud clicking noise; especially when i put it into drive. i have a feeling its a weak oil pump and that is the lifters clicking without oil?? i let it idle for a minute or two before driving anyways.. cheers! good to see some people still ripping these things http://i.share.pho.to/d58f1ae4_l.jpeg p.s my next car will most likely be a '05/'06 v70 2.5t Link to comment Share on other sites More sharing options...
VOLTA551568908589 Posted February 22, 2016 Author Report Share Posted February 22, 2016 Link to comment Share on other sites More sharing options...
pbfreak54001568908583 Posted February 23, 2016 Report Share Posted February 23, 2016 Yo I'm happy to see that you kept your car. Looking mint lol Link to comment Share on other sites More sharing options...
TEEKAY Posted February 24, 2016 Report Share Posted February 24, 2016 Link to comment Share on other sites More sharing options...
TEEKAY Posted February 24, 2016 Report Share Posted February 24, 2016 PS I like your garage doors. Link to comment Share on other sites More sharing options...
1clean00 Posted February 24, 2016 Report Share Posted February 24, 2016 The oil pumps rarely "fail" they could sometimes develop leaks around the gasket or the actual front crank seal. If the oil pump area itself is otherwise dry i wouldn't suspect oil pump unless you have actual oil pressure issues. If you don't have a warning lamp for oil pressure, and you do have "ticking" at 210K i'd suspect the bottom end o-rings in the oil pan have hardened or sludged and you're just not getting full oil flow to the top end. The true fix would be to drop the oil pan, clean out the bottom end, and reseal with new gaskets and o-rings. Otherwise, another solution would be to run thinner oil, like 5w30 or 0w30. Ticking could also be related to the vvt solenoid, or potentially even an exhaust leak that subsides when the engine is warmed and the metal expands to form a better seal. Link to comment Share on other sites More sharing options...
VOLTA551568908589 Posted February 24, 2016 Author Report Share Posted February 24, 2016 thanks @1clean00 once the engine is warmed up, she is totally fine. there are no oil leaks ( replaced alot of gaskets a couple months ago ) should i try this little trick to rule out vvt? Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted February 24, 2016 Report Share Posted February 24, 2016 given it's the 1.6 with a different ECU i wouldn't, pop off the timing cover and look for oil spots around the timing belt or on the pulleys/gears Link to comment Share on other sites More sharing options...
theForgottenone Posted February 25, 2016 Report Share Posted February 25, 2016 I'm gonna lean on that got tick noise Link to comment Share on other sites More sharing options...
1clean00 Posted February 25, 2016 Report Share Posted February 25, 2016 you can pull the solenoid connection while it is running and if you're simply idling the ecu won't care. I've done this to diagnose before on both the V40 and my T5. I'd wait until the engine was warm and do it then, when cold it really ticks all over the place anyway until it gets full oil flow and the cat and coolant warm up. Link to comment Share on other sites More sharing options...
1clean00 Posted February 25, 2016 Report Share Posted February 25, 2016 could also be evap purge valve, mine seems to tick more when its cold. Link to comment Share on other sites More sharing options...
VOLTA551568908589 Posted June 5, 2016 Author Report Share Posted June 5, 2016 Yeah.. ticking problem is much now with the warmer summer temperatures new problem on the horizon thoughPossible Boost Leak?*02 v40 auto with 225k, k&n, MBC PSI*-stays at the normal -25psi vacuum -rough idle at cold start up, but when warmed up its fine-very sluggish acceleration until the turbo spools up, even that, I never see it go more than around 5 or 6 psi-odd new whistling sound when slowly de-accelerating at around 1 psi ( not the normal boosh sound you get when letting of the acceleration )-when i do get a medium pull going (on-ramp), at around 5psi/ 3.5k rpm, there is a high pitch "weeee" sound that almost sounds electronic ....I have reset the cpu ie disconnected battery for 5 min to see if i can reset something (MAF?) Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted June 6, 2016 Report Share Posted June 6, 2016 Could be an o2 sensor, see if they look like this lol Link to comment Share on other sites More sharing options...
flyfishing31568908306 Posted June 6, 2016 Report Share Posted June 6, 2016 Do these cars have IAC's? Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted June 6, 2016 Report Share Posted June 6, 2016 Yea but it when those go symptoms are usually rough idle and hard starts Link to comment Share on other sites More sharing options...
