eajohnson Posted April 7, 2016 Report Share Posted April 7, 2016 I'm really stuck and hope someone can help me out. I'm outside a small town in Georgia a long way from the nearest dealer. vehicle stalled after running a few minutes at idle. won't restart, turns over fine but won't start. can't hear fuel pump when ignition is turned on. pulled codes with bsr tool with ignition turned to on position, get ecm 2900 fuel pressure control valve and and &ecm 290D fuel pressure codes. can't find the fuel of relay to check. what can I do from here? want to avoid a hundred mile tow. knowing location of the pump relay would be a good start. also is the point itself on the passenger side or driver side? so I can check voltage at the pump? Link to comment Share on other sites More sharing options...
eajohnson Posted April 7, 2016 Author Report Share Posted April 7, 2016 oops, that's 2005 v70r btw, phone trying to autocorrect Link to comment Share on other sites More sharing options...
eajohnson Posted April 8, 2016 Author Report Share Posted April 8, 2016 after letting it sit for a couple hrs the fuel pump comes on when i turn the ignition in, it starts right away but dies after five seconds or so. fuel filter maybe? or relay? I'd had no drivavility issues previously even at full throttle. Link to comment Share on other sites More sharing options...
eajohnson Posted April 8, 2016 Author Report Share Posted April 8, 2016 there has also been an antenna ring code, could this be antenna ring related even though the starter always engages just fine? Link to comment Share on other sites More sharing options...
coyoteturtle Posted April 10, 2016 Report Share Posted April 10, 2016 Im having the same problem. Did you find a solution? Link to comment Share on other sites More sharing options...
eajohnson Posted April 14, 2016 Author Report Share Posted April 14, 2016 not yet, towed car to a dealer they've had it all week no luck so far. replaced fuel pump they are replacing the Pump electronic module tomorrow as well as se wiring harness. Link to comment Share on other sites More sharing options...
UGETIT Posted April 18, 2016 Report Share Posted April 18, 2016 Please post the dealers findings. Good Luck. Kevin Link to comment Share on other sites More sharing options...
stringwalla Posted April 29, 2016 Report Share Posted April 29, 2016 this happened on my '04 last month. Couldn't find anything wrong. A computer reset fixed it. Mechanic assumed a voltage drop caused the network to go haywire. Been fine since Link to comment Share on other sites More sharing options...
