bigjoe25 Posted December 8, 2016 Report Share Posted December 8, 2016 I'm in the USA, that does seem to matter as no one on this side of the pond seems to tune these cars. Anyway I got a 2001 s40 1.9t for free, it's in great shape. Only thing is the stock output is kind of weak and I want to make it faster. I'm no stranger to volvos, I built a 300 horsepower redblock before. Anyway I've done some searching and I really cant find any performance upgrades for a 2001 s40. I was wondering what you guys do to make them go faster? I think 300 horsepower would be plenty, I don't need to go all out and go over 600 or anything too extreme. Link to comment Share on other sites More sharing options...
Diio Posted December 8, 2016 Report Share Posted December 8, 2016 Made a google translate on a usefull post on my forum here in sweden.. hope it helps Yes there's a lot of questions about what is needed to achieve a certain effect, so I was thinking the same set list. Remember that all vehicles / engines are different and provide different effects with the same trimmdelar. These are approximate figures on what you can possibly get. This applies 4 cyl engines for the S40 / V40. Kit for 280-300hk Turbo 16T / 18T / 19T happy with 7: ans angled exhaust house Adapter plate between the turbo and manifold Steel braided hoses for oil / water Manure from T4 phase 2 or S60R Converted fuel systems with return Sports exhaust from the turbocharger with sports / race catalyst (down spout needs to be modified to fit the exhaust house) 3 "LMM (if you have one phase 1) T4 or S60R connection may be needed if you have a 2.0t Ported manifold (happy phase2) Sport air filter Bosch platinum spark plug F5DP0R and a fine mapping of the ... Ideally, a Alloy intercooler oxå to cope with the boost in length. This operation runs well on all x40 turbo models, but not 2.0t phase 2 when its pistons probably disagree! Kit for 310-340hk Turbo 18T / 19T 7: ans angled exhaust house Adapter plate between the turbo and manifold Autotech camshafts (version kinder) Adjusted valves for new cam Verdi connecting rods Alloy intercooler Steel braided hoses for oil / water Manure from T4 phase 2 or S60R to 320hk, +500cc@3.8bar for more hp. Converted fuel systems with return Sports exhaust from the turbocharger with sports / race catalyst (down spout needs to be modified to fit the exhaust house) 3 "LMM (if you have one phase 1) S60R coupling Ported manifold (happy phase2) Sport air filter Bosch platinum spark plug F5DP0R Top from T4 phase 2 or fas1.5 and a fine mapping of the ... This procedure goes well on x40 T4 models. 2.0t blocks are a little weak so it can give itself after a while ... Kit for 340-360hk Turbo 19T 7: ans angled exhaust house Adapter plate between the turbo and manifold Autotech camshafts (version kinder) Adjusted valves for new cam Verdi connecting rods Alloy intercooler Steel braided hoses for oil / water Spreaders such Siemens 630cc@3.8bar decal or the like. Converted fuel systems with return Sports exhaust from the turbocharger with race catalyst (down spout needs to be modified to fit the exhaust house) 3 "LMM (if you have one phase 1) S60R clutch / Sachs clutch Ported manifold (happy phase2) Sport air filter Bosch platinum spark plug F5DP0R Top from T4 phase 2 or fas1.5 and a fine mapping on E85 ... This procedure goes well on x40 T4 models. 2.0t blocks are a little weak so it can give itself after a while ... Kit for 400hk + B4194T2 (T4 -00) motor or older t4 engine crankcase uppfräst Verdi connecting rods Larger turbo T03 / T04 turbocharger (eg T03 / 4E / S Step 5 axis T04E / S Step 3 axis, Cosworth exhaust house) Steel braided hoses for oil / water T4 or JE pistons Ported manifold Phase2 porting cylinder head Autotech camshafts (version sharper) Alloy intercooler 3 "exhaust system Modified fuel system with return +700cc@3.8bar Spreaders Worse clutch (850svänghjul with Sachs pressure plate) Extra fuel pump Rebuilt Oil return?!? Bosch platinum spark plug F5DP0R Sport air filter Double valve springs Adjusted valves for new cam After sales spray example Chesa / Motec / DTA and a fine mapping of the ... Then a little extra for the discerning: A diff to bring down effect Lowering with sports dampers Strut 17 "-18" wheels Better brakes (yellow tough & steel braided brake hoses or any Brembo / wilwoodkit) Various gauges (turbo and oil pressure, exhaust temperature ...) Motor Pillows & control arm bushings Polyurethane Good luck in the race for power Link to comment Share on other sites More sharing options...
