USSEnterprise Posted December 19, 2016 Report Share Posted December 19, 2016 Greetings! My name is Joe, I am 27 years old and live in New Jersey. I am considering purchasing a 2002 V40. It has 141,000 miles and needs some work. The issues with it is that it needs front shocks and it is stalling at traffic lights. It also needs the front right corner light replaced. Now, I'm not new to Volvo's. My first car was a 1995 850 Turbo, so I know some of their quirks. I figure that in addition to fixing whatever is wrong with it, I'd also do the timing belt and water pump, a full tune-up, the PCV system and the o2 sensors. Would this car be a good deal at $500? With proper care and maintenance, how long can these cars go for? Also, what can be done to it to liven it up? I know it's a 1.9 with a low pressure turbo putting out around 160. Could it be gotten to over 200 without spending a grand? I know i was able to get my 850 up to about 280 and I probably didn't spend more than $800. Your knowledge and wisdom is much appreciated! Thanks, Joe Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted December 19, 2016 Report Share Posted December 19, 2016 Don't even bother if you want performance out of it, find a different car. Link to comment Share on other sites More sharing options...
USSEnterprise Posted December 19, 2016 Author Report Share Posted December 19, 2016 Performance is not my priority, but if I could get it to 7 seconds 0 to 60, that would be nice. Mainly, I want to know how long lived these cars are and if it would be a reliable commuter car? Link to comment Share on other sites More sharing options...
theForgottenone Posted December 23, 2016 Report Share Posted December 23, 2016 They can be reliable car as DD if you will do their regular maintenance repairs. the stalling could be due to dirty fuel injectors, dirty MAF , or dirty Idle valve controller which locate by the throttle body. Link to comment Share on other sites More sharing options...
Diio Posted December 23, 2016 Report Share Posted December 23, 2016 Does this v40 have a turbo or not? Link to comment Share on other sites More sharing options...
USSEnterprise Posted December 24, 2016 Author Report Share Posted December 24, 2016 It's a 1.9 turbo. The car needs a lot of work, but they want so little for it at $400. It needs pads and rotors all around, has a very noticeable clunking sound from the front suspension when going over potholes and doesn't want to stay running on its own. When I plugged in my scanner, it shot out five codes. I don't remember them specifically, but I do rrmember the gist of them. 1. Fuel pressure too high 2. Misfire cylinder 3 3. Something related to the MAP sensor 4. Something concerning the coolant temperature sensor. 5. Some evaporative code. The engine wouldn't start without half throttle being applied while cranking, and the engine would stall if the RPM went under 1k. Additionally: The headliner is coming down The right rear window motor is bad The SRS light is on The owner is unclear as to whether the timing belt has ever been replaced. The only reason that I'm still considering this hunk of junk is because I'm hoping that making the huge amount of repairs on all the car's systems might give me more in-depth experience into auto repair. I'm going to back to look at it after Christmas. I'm going to get it up on jack stands to see what the hell is up with the front suspension, and the owner said he'll let me run a compression check for the hell of it Am I crazy/delusional or just stupid? Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted December 24, 2016 Report Share Posted December 24, 2016 run away Link to comment Share on other sites More sharing options...
Diio Posted December 27, 2016 Report Share Posted December 27, 2016 Well i dont know how the prices on cars is where you live but here in sweden that car would not cost more than 100 bucks ;> some codes can be old also. 1. Fuel pressure too high Just get a new fuel pressure regulator. 2. Misfire cylinder 3 problably bad coil or plugs. 3. Something related to the MAP sensor map sensor is easy to replace 4. Something concerning the coolant temperature sensor. same here, easy to replace (also cheap) 5. Some evaporative code. -have no idea The engine wouldn't start without half throttle being applied while cranking, and the engine would stall if the RPM went under 1k. Problably som vacuum leak or leaks between turbo and intake. Additionally: The headliner is coming down The right rear window motor is bad get a new one from scrap yard The SRS light is on Loose connector problably The owner is unclear as to whether the timing belt has ever been replaced. just change it. its not that hard but takes abit of time. there is alot of videos of this on youtube Depending of you mecanical skill. This car is a bit of a gamble becouse you dont have definitive errors. becouse some of the problems can be from many different things Link to comment Share on other sites More sharing options...
