tweekgt4 Posted January 12, 2017 Report Share Posted January 12, 2017 The turbo in my 99 V70R is now screaming. No smoke, just loud scraping noises. It's parked in the garage now waiting for me to figure out which turbo I can replace it with. The turbo in my 99 is a 18T. Short of looking for another 18T from another 99 V70R. What other turbos will just drop in with the same performance or better? I originally thought a turbo from a T5 would work but from a little research, they have 16T turbos. Will a 19T just drop in without a tune? Also, I have an Upsolute chip flash if that may make a difference. Thanks for any advice. Link to comment Share on other sites More sharing options...
Diio Posted January 12, 2017 Report Share Posted January 12, 2017 if you replace your 18T with a 19T you shuld do a tune for that Link to comment Share on other sites More sharing options...
ConorV70R Posted January 12, 2017 Report Share Posted January 12, 2017 18T and 19T flow about the same so you won't get that much of a difference. What about just rebuilding the 18T? Also is it straight flanged or angle flange because i know that the 19t's are angle flanged. Link to comment Share on other sites More sharing options...
tweekgt4 Posted January 15, 2017 Author Report Share Posted January 15, 2017 Angled flange. I thought about a rebuild kit but have to find someone who can rebuild it and also get a quality rebuild kit. I ordered a used turbo from LKQ but they sent one from a 2.4 AWD which was a 13T. I'll have to check in with them again on Monday if they are open to see if they have one from a 2.3l AWD.. The T5s are 16T so that won't work. Link to comment Share on other sites More sharing options...
tweekgt4 Posted January 19, 2017 Author Report Share Posted January 19, 2017 No go on the 2nd used turbo so I sent my old one off to be rebuilt. Link to comment Share on other sites More sharing options...
flyfishing31568908306 Posted January 25, 2017 Report Share Posted January 25, 2017 personally, i'd go K24 if you are going to do the work. def. will need a tune, maybe injectors also. Link to comment Share on other sites More sharing options...
tweekgt4 Posted February 6, 2017 Author Report Share Posted February 6, 2017 Turbo rebuilt by Cliff at Turbo Power in Cameron Park. http://www.turbo-power.com/ Cliff took care of the rebuild for a little under $500 plus shipping back to me. Turbo was installed earlier this week and the car feels way smoother and a lot quicker. I don't drive it as much as I used to so I can't report much more. My wife drives it daily and even she can tell there's a difference. Cliff said the turbo wasn't bad and was surprised I told him the turbo had about 203k miles. It had a little shaft play and some carbon build-up which was mostly likely why I heard some screaming that went away. With the Upsolute Tune way I had done back when and now with the rebuilt turbo, I had seen boost spikes of 1.6 Bar during the limited test drives I've had. I'll report if we blow the engine (hope not!). I haven't had much of a chance to test drive the car but it doesn't always spike to 1.6 Bar. IIRC, I used to see 1.2-1.4 on the old turbo. Thanks again for all the replies! Link to comment Share on other sites More sharing options...
flyfishing31568908306 Posted February 6, 2017 Report Share Posted February 6, 2017 if everything is proper ( stage 0) 1.6 should be fine. my tune is set for 1.8. Just drive smartly. Link to comment Share on other sites More sharing options...
Big Will Posted May 1, 2017 Report Share Posted May 1, 2017 On 2/6/2017 at 8:57 AM, flyfishing31568908306 said: if everything is proper ( stage 0) 1.6 should be fine. my tune is set for 1.8. Just drive smartly. You're boosting 26 PSI?! That's a lot of boost. Link to comment Share on other sites More sharing options...
flyfishing31568908306 Posted June 26, 2017 Report Share Posted June 26, 2017 come to think of it, that is high. i'll have to go look again. iirc it might be 20lbs Link to comment Share on other sites More sharing options...
sabrina090 Posted August 31, 2017 Report Share Posted August 31, 2017 I am also curious about that. Link to comment Share on other sites More sharing options...
