olfac87 Posted July 19, 2017 Report Share Posted July 19, 2017 Hoping someone can steer me right (no pun intended). The issue is a periodic error: Anti-skid Service Required followed by Chassis Settings Temporarily Disabled. I am not quite sure when it happens. It might stay on for a ride or two and then disappear for a week or two. I had a Volvo specialist run a diagnostic; the report is attached/below. Their suggestion was that I replace the steering angle sensor (behind the steering wheel). Does that sound like the best course of action? Any other ideas? Thank you. Link to comment Share on other sites More sharing options...
olfac87 Posted July 20, 2017 Author Report Share Posted July 20, 2017 I found a nice write-up on replacing the SAS if that is the root cause. Any ideas based on the report attached? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted July 28, 2017 Report Share Posted July 28, 2017 Would definitely start with a steering angle sensor (clockspring) with that DTC. Link to comment Share on other sites More sharing options...
olfac87 Posted July 29, 2017 Author Report Share Posted July 29, 2017 18 hours ago, Ihatespeedbumps said: Would definitely start with a steering angle sensor (clockspring) with that DTC. Thank you. It helps to have another confirming voice before I buy a $300+ part. Link to comment Share on other sites More sharing options...
ssscoots Posted August 10, 2017 Report Share Posted August 10, 2017 I also have an '07. Mine has roughly 185K miles on the clock and recently had the same symptoms. I bit the bullet and replaced the sensor. It was the right move and has returned the car to "normal". Link to comment Share on other sites More sharing options...
