PLANT Posted August 17, 2017 Report Share Posted August 17, 2017 Hi all, Looking at buying an OBD2 bluetooth(Android phone) Any cheap recommendations? Have seen Youtube video working with this model but also have seen pull down menus that says it is not compatible? Looking at this on Ebay: We will carefully check every item before shipment. The quality is guaranteed! Note: Russian buyers were required to fill in the full name ( normally including the name, father's name and surname,three individual words) in the shipping address to pick up the item as the Russian postal policy adjustments. Smaller size mini car Bluetooth diagnostic scanner works on Android Torque/PC, which can help you diagnose the trouble of your car!Features: This mini car bluetooth diagnostic scanner works on Android Torque/PC with the latest software version V2.1 and hardware Version V1.5. Bluetooth Password: 1234 Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database). Clear trouble codes and turn off the MIL ("Check Engine" light). Display current sensor data, including: * Engine RPM * Calculated Load Value * Coolant Temperature * Vehicle Speed * Timing Advance * Fuel System Status * Fuel Pressure * Short Term Fuel Trim * Long Term Fuel Trim * Intake Manifold Pressure * Intake Air Temperature * Air Flow Rate * Absolute Throttle Position * Oxygen sensor voltages/associated short term fuel trims Specifications: Support OBD-II protocols as follows: 1.ISO9141-2(5 baud init,10.4Kbaud) 2.ISO14230-4 KWP(5 baud init,10.4Kbaud) 3.ISO14230-4 KWP(fast init,10.4Kbaud) 4.ISO15765-4CAN(11bit ID,500 Kbaud) 5.ISO15765-4CAN(29bit ID,500 Kbaud) 6.ISO15765-4CAN(11bit ID,250 Kbaud) 7.ISO15765-4CAN(29bit ID,250 Kbaud) Compatibility: * Works on all OBD2 petrol cars ( from 1996 in USA). * Compatible with Android Torque and Windows Smartphone, Windows PC. Product Size: 7 * 4.5 * 2.5cm / 2.8 * 1.8 * 1in Product Weight: Approx.47g / 1.7oz Package Size: 13.5 * 10 * 3cm / 5.3 * 3.9 * 1.2in Package Weight: Approx.47g / 1.7oz Note: It is not compatible with Nissan vehicles. Package List: 1 * Bluetooth Diagnostic Scanner 1 * CD Link to comment Share on other sites More sharing options...
PLANT Posted September 9, 2017 Author Report Share Posted September 9, 2017 So I got an Ebay ELM327......came with 2.1 Firmware plugging in the power lights face the pedals.... So I got it going and default Dials are Speed and Acceleration worked. My Boost psi and Throttle did not work(have a turbo)???? Got home and looked at this you tube video: https://www.youtube.com/watch?v=GMYZNal9Wpk Found the other dials and have it setup for 6 on the phone. Have added MAF and Coolant. What DIALS do you have setup on yours? Now I checked the logged\pending codes and it produced an Ignition Coil code....I just had them replaced....the mechanic did not reset codes? Show historic faults.....had none? Link to comment Share on other sites More sharing options...
PLANT Posted September 10, 2017 Author Report Share Posted September 10, 2017 So the PO352 Pending\Fault code won't clear? This fault(Ignition Coil B Primary/Secondary Circuit Malfunction) is "not" showing on the dashboard and I understood fixed by replacement of parts? Why won't the fault clear on Torque Lite? Dials update MAF and Fuel level don't work, Coolant and RPM does work. Link to comment Share on other sites More sharing options...
TEEKAY Posted September 13, 2017 Report Share Posted September 13, 2017 I use the DashCommand app with iOS so I can't comment on the dials and such for Torque. It could clear by itself after some use. I usually use Vida/Dice to clear the troublesome codes. Even if I clear misfire codes with DashCommand it takes some number of drive cycles to clear. Link to comment Share on other sites More sharing options...
PLANT Posted September 15, 2017 Author Report Share Posted September 15, 2017 So I got an Ebay ELM327......came with 2.1 Firmware plugging in the power lights face the pedals.... So I got it going and default Dials are Speed and Acceleration worked. My Boost psi and Throttle did not work(have a turbo)???? Got home and looked at this you tube video: https://www.youtube.com/watch?v=GMYZNal9Wpk Found the other dials and have it setup for 6 on the phone. Have added MAF and Coolant. What do DIALS do you have setup on yours? Now I checked the logged\pending codes and it produced an Ignition Coil code....I just had them replaced....the mechanic did not reset codes? Show historic faults.....had none? Edit: So the Pending\Fault code won't clear? This fault is "not" showing on the dashboard and I understood fixed by replacement of parts? Why won't the fault clear on Torque Lite? Dials update MAF and Fuel level don't work, Coolant and RPM does work. Edit2: Will try this to clear codes....http://www.e90post.com/forums/showthread.php?t=1249867 With Torque, try having the car such that the ignition is on, but the engine is not running, then touch the clear code button, then turn the ignition off. This should work to clear the codes. Edit3: The above clears the codes CONFIRMED! Link to comment Share on other sites More sharing options...
