labans Posted September 21, 2019 Report Share Posted September 21, 2019 I had to replace the fuel pump at 180,000 due to leakage and noise. From experience I purchased a Volvo fuel pump; this pump then failed at 192,000 so I sent it in on warranty (FCP, the Best) and purchased the identical pump which I just installed. However, when hooking up the plugs I find that this pump has one extra connection that I cannot find a mate for anywhere so I am asking if someone can help by letting me know either where the plug goes, or if it is not used on my model. The plug to which I am referring is the WHITE one, a single male connector with a BLACK wire going to it, in the center of the photo between the two black plugs. Many Thanks in advance. Link to comment Share on other sites More sharing options...
apeacock Posted September 22, 2019 Report Share Posted September 22, 2019 I would guess black wire is a ground? if it goes back together and doesn't work, run that somewhere on the chassis so that it can be grounded and go from there. Weird though! Link to comment Share on other sites More sharing options...
