misa Posted November 2, 2019 Report Share Posted November 2, 2019 Is instrument cluster from s,v70 from '97 or '98 compatible with 850? I know that '99+ will not work because of CAN protocol. Is it direct fit to 850? I have broken odo gear(s) and i would like to upgrade to a digital odo which s,v70 have. Link to comment Share on other sites More sharing options...
MattyXXL Posted November 3, 2019 Report Share Posted November 3, 2019 In to your 97... Yes Pre 95 no. Go go for a VR cluster, the Blue is nicer to look at Link to comment Share on other sites More sharing options...
misa Posted November 4, 2019 Author Report Share Posted November 4, 2019 So...no modifications of any kind required for '97 850? What about cosmetic look? Some says that s,v70 cluster is different shaped and doesn't physically fit the best way around edges. Did somebody allready performed this kind of modification/upgrade? I would like to see the pictures of how it fits in 850. Link to comment Share on other sites More sharing options...
MattyXXL Posted November 6, 2019 Report Share Posted November 6, 2019 On 11/4/2019 at 4:15 AM, misa said: So...no modifications of any kind required for '97 850? What about cosmetic look? Some says that s,v70 cluster is different shaped and doesn't physically fit the best way around edges. Did somebody allready performed this kind of modification/upgrade? I would like to see the pictures of how it fits in 850. I ran it in my 96 for years, let me see if I can find pictures No mods needed, its plug and play as long as its a 98 cluster. 99 and up clusters wont do something from what i remember Link to comment Share on other sites More sharing options...
misa Posted November 6, 2019 Author Report Share Posted November 6, 2019 Pictures would be great! Link to comment Share on other sites More sharing options...
bmdubya1198 Posted November 6, 2019 Report Share Posted November 6, 2019 99 cluster will fit and plug in too, but I don't think it'll work because it's part of the CAN bus network. I don't know exactly what doesn't work, but I know it's not compatible with the '98 and older cars. As long as you use a '98 cluster, it should be no problem as far as fitment. Link to comment Share on other sites More sharing options...
misa Posted November 7, 2019 Author Report Share Posted November 7, 2019 Are part numbers of the cluster from '98 and '99 different? I found one locally,but don't know from which year the car was. Link to comment Share on other sites More sharing options...
apeacock Posted November 7, 2019 Report Share Posted November 7, 2019 7 hours ago, misa said: Are part numbers of the cluster from '98 and '99 different? I found one locally,but don't know from which year the car was. I would think so yea. If anything the symbols are a bit different, Lambda to CEl, the Odometer stays on all the time in a 98 where as the 99+ is turns off after a set time. (thought maybe that's ecu related?) Link to comment Share on other sites More sharing options...
bmdubya1198 Posted November 8, 2019 Report Share Posted November 8, 2019 I think so, yes. Be careful with that PN on the back though, that's for the back cover, not the cluster. That should be the same between '98 and '99 models. Link to comment Share on other sites More sharing options...
misa Posted November 8, 2019 Author Report Share Posted November 8, 2019 Can somebody post part numbers for '97-'98 cluster(EU had s,v70 from '97) and for '99+? I can't take it back when i buy it. Just want to be sure. Link to comment Share on other sites More sharing options...
bmdubya1198 Posted November 9, 2019 Report Share Posted November 9, 2019 According to VIDA, the PN for 1998 MY is 9459557. This PN is for the "wiring plate" (circuit board), so that may be the same in the European market. However I'm not 100% sure on that because I know the EU clusters are different with the KM/H speedo, L/100 KM fuel gauge, and some warning lights and whatnot. 1999 PN for the same part is 9451507. Hopefully this can be of some help for you! You'll probably have to remove that back cover to see this number, though. Link to comment Share on other sites More sharing options...
misa Posted November 9, 2019 Author Report Share Posted November 9, 2019 Thanks bmdubya1198. We'll see what i can find. Link to comment Share on other sites More sharing options...
misa Posted November 10, 2019 Author Report Share Posted November 10, 2019 I found one from '98 but it's a 10v car. https://www.vindecoder.pl/YV1LW5102W2502993 Will it work into 20v car? Link to comment Share on other sites More sharing options...
misa Posted November 10, 2019 Author Report Share Posted November 10, 2019 On 11/6/2019 at 1:43 AM, MattyXXL said: I ran it in my 96 for years, let me see if I can find pictures No mods needed, its plug and play as long as its a 98 cluster. 99 and up clusters wont do something from what i remember Can you post a pictures? Does it match edges perfectly ...just like 850 cluster? EDIT: Never mind...i just found what i was looking for: http://www.vpcuk.org/forums/showthread.php?57561-v70-dash-clocks-in-an-850-t5&highlight=s%2Cv70+clocks+into+850 It shouldn't matter if the car is 10v or 20v...isn't it? Link to comment Share on other sites More sharing options...
bmdubya1198 Posted November 11, 2019 Report Share Posted November 11, 2019 I can't say for sure being that we didn't get 10v cars here in the States, but I would think you could use it no problem. Link to comment Share on other sites More sharing options...
