8501995 Posted April 30, 2005 Report Share Posted April 30, 2005 Hi,I changed my front sway bar this morning (which went pretty good!) and realized that the top (anti-vibration) engine mount is broken. (I might have broken it when I lowered the subframe!) The rubber part inside is broken in two parts. I guess it's not that bad, but I should change it.Can anyone tell me what is the part number for that? I figure I'd have to remove the mount that's bolted on the engine (reaches way down, could be hard to reach!) and then remove the rubber part and replace it...Here are some pictures:http://www.ece.concordia.ca/~s_lemay/mount/It's a Volvo 850 1995 GLEThanks! Link to comment Share on other sites More sharing options...
WhiteT5 Posted April 30, 2005 Report Share Posted April 30, 2005 Hey. This happens to all of the 850/70 series cars eventually. You'll be MUCH better off replacing it with the IPD or EST polyurethane mount. It won't wear out ever. Link to comment Share on other sites More sharing options...
8501995 Posted April 30, 2005 Author Report Share Posted April 30, 2005 Thanks for the reply. Found it on IPD http://www.ipdusa.com/ProductsCat.aspx?Cat...4720&RootID=62926$US is a bit expensive for what I use the car for I guess.Can I just change the rubber part with the original Volvo part? Link to comment Share on other sites More sharing options...
ludman Posted April 30, 2005 Report Share Posted April 30, 2005 Thanks for the reply. Found it on IPD http://www.ipdusa.com/ProductsCat.aspx?Cat...4720&RootID=62926$US is a bit expensive for what I use the car for I guess.Can I just change the rubber part with the original Volvo part?←I got a quote to replace my aftermarket mount from my dealer when I took my car in for the fule tank and seat heater recalls for $160 installed. check out from www.fcpgroton.com. They have them for a bit cheaper. It does transmit a bit more vibration to the steering wheel but will last forever. Takes about 15 minutes to install. Link to comment Share on other sites More sharing options...
merlin390 Posted April 30, 2005 Report Share Posted April 30, 2005 not to be rude but $26 for a mount that will probably out live the car is not a bad price FCP groton look for part number 9434288 or 9434263Uthe stock design WILL break again. the urathane ones will not. Link to comment Share on other sites More sharing options...
WhiteT5 Posted April 30, 2005 Report Share Posted April 30, 2005 Thanks for the reply. Found it on IPD http://www.ipdusa.com/ProductsCat.aspx?Cat...4720&RootID=62926$US is a bit expensive for what I use the car for I guess.Can I just change the rubber part with the original Volvo part?←I bet the Volvo one is a comparable price, if not more expensive, and it'll just break again. Link to comment Share on other sites More sharing options...
8501995 Posted May 1, 2005 Author Report Share Posted May 1, 2005 Does anyone have the part number, so I can call the Volvo dealer and ask for a price?Thanks! Link to comment Share on other sites More sharing options...
Bay13 Posted May 1, 2005 Report Share Posted May 1, 2005 9434263 is the part number, try the dealer and then consider http://www.FCPgroton.comFCPgroton list the part as number 9434299 and it costs $9. Link to comment Share on other sites More sharing options...
Kibim Posted May 1, 2005 Report Share Posted May 1, 2005 Hey. This happens to all of the 850/70 series cars eventually. You'll be MUCH better off replacing it with the IPD or EST polyurethane mount. It won't wear out ever.←Eventually?! Darn, mine has broken every service interval! I bought and IPD Poly-mount which was cheaper to ship from the US than buy the OEM mount here. Agents here were impressed with it! Link to comment Share on other sites More sharing options...
