98s70t5mvt Posted June 24, 2020 Report Share Posted June 24, 2020 Bought an 04 c70 b5234t9 to swap Have Fuel rail with blues $30 ETM with intake manifold $80 Auto flex plate $30 P80 Sas pump $50 850 x70 air box $50 Exhaust manifold $20 New obx straight flange downpipe $200 Straight flange housing $55 (no cracks) Stock straight flange downpipe with cat $100 Used td04hl-16t p80 feed ports, little to no shaft play $100 Low mileage (60k) td04hl-16t p2 style feed , no shaft play $200 Snail turbo cnc billet wastegate actuator fits straight and angle flange with 1 bar spring brand new valued $140 will sell $80.. Snail turbo - Td04hl-22t billet 6+6 (td05-18g) wheel extended tip 50mmx71mm with 9 blade turbine. Silicone hd cbv with medium spring 14-18psi Has 4 open coolant port with plugs Paid $960 was dropped by a friend and seems have some rubbing when spun by hand. Never installed so essentially new Will sell for $400 fp offers rebuild for $275. My loss is your gain. Good for around 320-360whp depending on boost and fuel.. Possible it's fine but had 2 so went with the other... Link to comment Share on other sites More sharing options...
98s70t5mvt Posted June 26, 2020 Author Report Share Posted June 26, 2020 Also have a 98 s70 t5m ecu ending 450.. $75 Link to comment Share on other sites More sharing options...
