Rigosaurus rex Posted February 28, 2021 Report Share Posted February 28, 2021 I have the engine code 'p0016 crankshaft position - camshaft position correlation bank 1 sensor A' which usually relates to timing. The car came with this code but had a terribly damaged water pump which would have loosened the belt somewhat. I replaced the water pump and lined up the timing marks. The code still exists and the car runs poorly at certain revs/ speeds (vibration) and is thirsty. Doing some research I think I didn't load the exhaust cam spring properly so even though the mark is right the cam could be a tooth or 2 off. If that is the case to retime it do I need to buy a cam lock or can I load it but turning anticlockwise then clockwise or vice versa. Thanks Rigs Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 1, 2021 Report Share Posted March 1, 2021 You need to lock the cams and re-time the engine. Link to comment Share on other sites More sharing options...
