Guest Guest_smoothdmn_* Posted May 10, 2005 Report Share Posted May 10, 2005 1999 C70 rear speakers go on and off. Could this be amp related? loose connection? Car has Dolby pro logic. any IdeasThanks Link to comment Share on other sites More sharing options...
theunderlord Posted May 10, 2005 Report Share Posted May 10, 2005 1999 C70 rear speakers go on and off. Could this be amp related? loose connection? Car has Dolby pro logic. any IdeasThanks←just the rears.. check your connections? maybe you have gremlins that change your fader when you're not looking ? Link to comment Share on other sites More sharing options...
gdizzle Posted May 10, 2005 Report Share Posted May 10, 2005 Im having the same sort of problem in my V70. I think it's the amp, but when I smack the speaker, it will sometimes come back indicated a loose connection. I need to investigate more. Link to comment Share on other sites More sharing options...
DouginDenver Posted May 11, 2005 Report Share Posted May 11, 2005 1) Does it do it in the modes other than Pro Logic, and 2) does it behave the same whether it's radio or a CD? I have learned that in radio mode, Pro Logic is very sensitive to signal strength and the rear speakers appear to cut in and out. It's very annoying, and I live in a big city where the transmitters are close by. So if it is doing it only in radio mode, it's normal. If it does it in CD mode as well, then you have another problem. Link to comment Share on other sites More sharing options...
theunderlord Posted May 11, 2005 Report Share Posted May 11, 2005 I'm gonna move this to audio, see if that helps ya.. Link to comment Share on other sites More sharing options...
ViperVettte Posted May 11, 2005 Report Share Posted May 11, 2005 lol Smacking things usually don't have the best effects. Like this one time my sister was getting all upity.... oh god, that didn't end well. Def. 1st step is to check the connections, then go after the amp.... you prolly want to avoid step two as much as possible. Unless you are like me and just look for reasons to go after market. V Link to comment Share on other sites More sharing options...
