Slater Posted May 11, 2005 Report Share Posted May 11, 2005 I have 100k+ on my 95 850, and want to go ahead and replace the oil seperator tank when I service the PCV hoses and whatnot.However, VADIS lists 2 different tanks. Which is the right part number? Does one superceed the other?Is there any other seals or orings I should replace related to the tank? I already have the 90 degree elbow coupling that goes into the tank. I'm thinking there should be some sort of coupling or oring or something where the tank attaches to the block...Thanks!- Slater Link to comment Share on other sites More sharing options...
Slater Posted May 11, 2005 Author Report Share Posted May 11, 2005 bumphelp me out on this one - I know a lot of you have replaced your oil seperator... Link to comment Share on other sites More sharing options...
merlin390 Posted May 11, 2005 Report Share Posted May 11, 2005 Slater there are two styles based on the engine serial number. I do not remember the cut off number but thats why there is two. Link to comment Share on other sites More sharing options...
prasamin Posted May 11, 2005 Report Share Posted May 11, 2005 Slater, when you find out, I'd like to know which one it is too, and how you figure it out....also would like to know P/N's for the orings and connectors you replace....I really need to do this, but have so much other stuff going on right now!-Pras- Link to comment Share on other sites More sharing options...
WhiteT5 Posted May 11, 2005 Report Share Posted May 11, 2005 Slater, look at the engine code number that should be on a sticker on the timing belt cover. Here's the info you need:For engines up to 330413, you need part number 9146756.For engines 330414 and later, you need part number 1271988.There aren't any seals related to the box that you need to worry about, but it would be good to make sure all of the lines being routed to and from the PCV to the head and to the air intake hose are free of obstructions. Also, while you have the manifold off, clean up the knock sensors and their connections, but pay attention to their original position and make sure they're put back the way they're found. Also, it would be good to go ahead and replace the vacuum elbow over on the passenger side of the manifold while you have easy access to it. Link to comment Share on other sites More sharing options...
Slater Posted May 11, 2005 Author Report Share Posted May 11, 2005 Slater, look at the engine code number that should be on a sticker on the timing belt cover. Here's the info you need:For engines up to 330413, you need part number 9146756.For engines 330414 and later, you need part number 1271988.There aren't any seals related to the box that you need to worry about, but it would be good to make sure all of the lines being routed to and from the PCV to the head and to the air intake hose are free of obstructions. Also, while you have the manifold off, clean up the knock sensors and their connections, but pay attention to their original position and make sure they're put back the way they're found. Also, it would be good to go ahead and replace the vacuum elbow over on the passenger side of the manifold while you have easy access to it.←Awesome - that's exactly what I was looking for!Thanks! Link to comment Share on other sites More sharing options...
MrWinkey Posted May 12, 2005 Report Share Posted May 12, 2005 Another case solved by the white rat....I love that mouse...I just can't figure out where I have seen him before...go easy on me now I'm not as young as some of you guys....is it Pinky and the Brain?...Not futurarama?..aahhh..atleast you got him straight on the oil trap issue ;) Link to comment Share on other sites More sharing options...
merlin390 Posted May 12, 2005 Report Share Posted May 12, 2005 it is pinkey and the brain Link to comment Share on other sites More sharing options...
MrWinkey Posted May 12, 2005 Report Share Posted May 12, 2005 it is pinkey and the brain←Sweet...well I'm not feelin so old now:)...never watched it but have seen it in surfing the channels as all middle aged beer gutted guys do Your day is coming :lol: Link to comment Share on other sites More sharing options...
prasamin Posted May 12, 2005 Report Share Posted May 12, 2005 Sean, he just called you a white rat. :P Link to comment Share on other sites More sharing options...
merlin390 Posted May 12, 2005 Report Share Posted May 12, 2005 Sweet...well I'm not feelin so old now:)...never watched it but have seen it in surfing the channels as all middle aged beer gutted guys do Your day is coming ←if I am still around then I will let ya know OLD MAN!! Link to comment Share on other sites More sharing options...
