mAydAy Posted January 29, 2007 Report Share Posted January 29, 2007 Well since its back up here, if anyone wants one mine is definitely available. Link to comment Share on other sites More sharing options...
gt90 Posted January 30, 2007 Report Share Posted January 30, 2007 Well since its back up here, if anyone wants one mine is definitely available.How much? Link to comment Share on other sites More sharing options...
the ünderstüdy Posted January 30, 2007 Report Share Posted January 30, 2007 Man this is addictive. The car is a totally different animal! I can't wait to feel it once I put the down pipe, exhaust, GLT cams, and CAI on!Anyways, at WOT my stock needle goes right to the end of the white and stays right there all the way to redline. It's my understanding that the end of the white is 15psi. Is that correct?The BSR Stage 3 is supposed to be 18psi which is why I'm wondering.No, I don't have my Defi boost gauge hooked up yet. I know the stock gauge is crap but only because it's slow to repsond.- SlaterDidnt you swap Jason for a bit??? I might be thinking of someone else. BoostJunkie (Jason) was running the bSR stage III and he said it holds 18psi till almost redline i think. Says it pulled sooo much more aggressively then his Speedtuning chip. Looking into this tuning as well, thanks for the great response Slater. Link to comment Share on other sites More sharing options...
RAzOR Posted January 30, 2007 Report Share Posted January 30, 2007 The 15G with DP and cat-back will surge to well over 17 psi on downshifts. When you run the Upsolute, throw in a MBC and see what it will do. The Uspolute maps that I have had have been very rich and work well with balls-out MBC settings.I calibrated my factory gauge and it was 15psi at the end of the white bar under the stock gauge. Link to comment Share on other sites More sharing options...
ToxicLemonade Posted January 30, 2007 Report Share Posted January 30, 2007 18psi is what BSR claims.So it's the 15G wg actuator holding me back? Or the stock BCS?Its the stock exhaust holding you back for sure. with my ST 17psi chip i would only see 14-15 psi with stock exhaust. Put the 3inch dp and ehxuast on and got my money's worth. Link to comment Share on other sites More sharing options...
ovlov780t Posted January 31, 2007 Report Share Posted January 31, 2007 I Got one im tryna get rid of. practically brand new. (boost gauge that is) Link to comment Share on other sites More sharing options...
