Guest Guest_Mark_* Posted May 14, 2005 Report Share Posted May 14, 2005 I am having difficulty separating the steering rack from the shaft. I have removed the bolt, but I cannot separate the steering rack from the steering shaft. Is there a trick? Link to comment Share on other sites More sharing options...
Bay13 Posted May 14, 2005 Report Share Posted May 14, 2005 A long pry bar, and a hammer to knock it up and off the shaft on the Power steering rack.After it's off you might want to use something to spread it a little so it will go back on the PS shaft when you put it back together. Link to comment Share on other sites More sharing options...
Guest Guest Posted May 14, 2005 Report Share Posted May 14, 2005 Thankyou,I finally got the rack and the column separated, it seems like it was quite rusted together. Now I'll see if I can squeeze the rack out. The subframe is lowered, but it still is not a lot of clearance. We'll see.Thanks again. Link to comment Share on other sites More sharing options...
