1ajs Posted May 17, 2005 Report Share Posted May 17, 2005 how do i fix my gas gadge on my 72 145s? it reads either higher then there is or less then there actuly is. Link to comment Share on other sites More sharing options...
Ivanfbi Posted May 17, 2005 Report Share Posted May 17, 2005 take your gas tank off, carefull not to spill the fuel, then, take a vaccuum(like a shop vaccuum) and start pumping the oil out, and run as fast as you can. you won't need no gauge no more after this "fix" Link to comment Share on other sites More sharing options...
Three Fat Tigers Posted May 17, 2005 Report Share Posted May 17, 2005 how do i fix my gas gadge on my 72 145s? it reads either higher then there is or less then there actuly is.←Odds are your fuel sending unit will need to be replaced. The sending unit has a board with a single fine wire wrapped around it like 50 times, this wire will at some point in time, develope breaks, and that will cause the erratic readings of the type you describe. This is a common failure in these early sending units. Otherwise if the sending unit is fine, then the gauge is suspect. To test the gauge, disconnect the sending unit connector under the cargo floor and connect a potentiometer set for 68 ohms between the sensor wire and ground, the gauge should then read 3/4 scale.take your gas tank off, carefull not to spill the fuel, then, take a vaccuum(like a shop vaccuum) and start pumping the oil out, and run as fast as you can. you won't need no gauge no more after this "fix"← Link to comment Share on other sites More sharing options...
1ajs Posted May 26, 2005 Author Report Share Posted May 26, 2005 take your gas tank off, carefull not to spill the fuel, then, take a vaccuum(like a shop vaccuum) and start pumping the oil out, and run as fast as you can. you won't need no gauge no more after this "fix"←i love my volvo why would i blow it up Link to comment Share on other sites More sharing options...
Ivanfbi Posted May 31, 2005 Report Share Posted May 31, 2005 for fun, by the way, i always had something with rwd volvos, like get one for $49-50 and set it on fire Link to comment Share on other sites More sharing options...
