carter23 Posted May 18, 2005 Report Share Posted May 18, 2005 I received the dreaded ETS light yesterday so I decided to purchase an ODBII reader. Purchased an Actron 9135, pulled the codes and it listed two codes - P1603 which translates to IAC Valve Closing Signal and code P1610 which is Ignition Discharge Module (IDM) Group D . Since I own the Vadis software I figured I could plug the info into Vadis and find something on it?? BUT, no luck!! The car is a 2000 S70.Any help is greatly appreciated!!Thank You Link to comment Share on other sites More sharing options...
Pauloil Posted May 18, 2005 Report Share Posted May 18, 2005 perhaps converting these codes to the volvo codes using data from alldatadiyl.com would help you use the vadis. Link to comment Share on other sites More sharing options...
carter23 Posted May 19, 2005 Author Report Share Posted May 19, 2005 Thanks for the reply! How would I "convert" to Volvo codes? Link to comment Share on other sites More sharing options...
Guest Guest Posted May 19, 2005 Report Share Posted May 19, 2005 engine>diagnostics>general>obdII conversion Link to comment Share on other sites More sharing options...
MrWinkey Posted May 19, 2005 Report Share Posted May 19, 2005 I received the dreaded ETS light yesterday so I decided to purchase an ODBII reader. Purchased an Actron 9135, pulled the codes and it listed two codes - P1603 which translates to IAC Valve Closing Signal and code P1610 which is Ignition Discharge Module (IDM) Group D . Since I own the Vadis software I figured I could plug the info into Vadis and find something on it?? BUT, no luck!! The car is a 2000 S70.Any help is greatly appreciated!!Thank You←Actually ..I have those codes tattooed in the back of my skull anymore..you need an ETM sorry? ;) Link to comment Share on other sites More sharing options...
Guest Guest Posted May 22, 2005 Report Share Posted May 22, 2005 Actually ..I have those codes tattooed in the back of my skull anymore..you need an ETM sorry? ←ETM - ?? Link to comment Share on other sites More sharing options...
MrWinkey Posted May 22, 2005 Report Share Posted May 22, 2005 ETM...ETH....Electronic Throttle Module,,,,Electronic Throttle Housing Link to comment Share on other sites More sharing options...
