Guest Guest_parker2520_* Posted May 20, 2005 Report Share Posted May 20, 2005 O.K. Can someone please tell me, difinitively, what type atf fluid replaces the fluid in my 2000 XC AWD Turbo, Auto trans. Many thanks...... Link to comment Share on other sites More sharing options...
Bay13 Posted May 20, 2005 Report Share Posted May 20, 2005 Do you know where your trans dip stick is? If you pull it out how long is it? What does your gear selector say? P R N D 4 3 2 L ?Answer those questions and I can tell you if you need Dexron III or the synthetic stuff.I'm pretty sure you take the Dexron III transmission fluid. Link to comment Share on other sites More sharing options...
Guest Guest_parker2520_* Posted May 21, 2005 Report Share Posted May 21, 2005 Gear selector says " P R N D 3 2 1 "the length of the stick is 15 and 1/2 inchs' from the o-ring, 18 inch total Link to comment Share on other sites More sharing options...
Bay13 Posted May 21, 2005 Report Share Posted May 21, 2005 You take DEXRON IIIif you took the volvo synthetic, your dip stick would be about 9 inches and very hard to find. Your shifter would say, P R N D 4 3 2 L.But you can use Mobil 1 synthetic cause it's DEXRON III or equivilant if you want to use a synthetic or even Redline D4 which is what I'm using. Link to comment Share on other sites More sharing options...
merlin390 Posted May 21, 2005 Report Share Posted May 21, 2005 Files this away in the useful knowledge section Link to comment Share on other sites More sharing options...
Guest Guest_parker2520_* Posted May 21, 2005 Report Share Posted May 21, 2005 Rich: Thanks for making that perfectly clear.... Link to comment Share on other sites More sharing options...
slarti Posted May 23, 2005 Report Share Posted May 23, 2005 The volvos with synthetic dont have neutral? Link to comment Share on other sites More sharing options...
Bay13 Posted May 23, 2005 Report Share Posted May 23, 2005 Nice catch, yes they have neutral, I just left it out. Link to comment Share on other sites More sharing options...
ac102nv Posted July 20, 2005 Report Share Posted July 20, 2005 if you took the volvo synthetic, your dip stick would be about 9 inches and very hard to find. Your shifter would say, P R N D 4 3 2 L.OK, so I need the synthetic stuff....where can I get this? Is it a dealer only item? I hope not, they quoted my $23 a qt. Link to comment Share on other sites More sharing options...
the underlørd Posted July 20, 2005 Report Share Posted July 20, 2005 if you took the volvo synthetic, your dip stick would be about 9 inches and very hard to find. Your shifter would say, P R N D 4 3 2 L.OK, so I need the synthetic stuff....where can I get this? Is it a dealer only item? I hope not, they quoted my $23 a qt.←Redline Link to comment Share on other sites More sharing options...
Bay13 Posted July 21, 2005 Report Share Posted July 21, 2005 Actually Redline doesn't make 3309 specs fluid. I was talking with them and they wanted me to send them the specs. Ha, like I know what the fluid specs for 3309 are? Anyway, Mobil has a 3309 specs, they actually make it for Volvo. So right now it's Mobil 3309 or the Volvo dealer. Link to comment Share on other sites More sharing options...
ac102nv Posted July 21, 2005 Report Share Posted July 21, 2005 Thank you!! Link to comment Share on other sites More sharing options...
Guest sligo Posted July 22, 2005 Report Share Posted July 22, 2005 1999 V70 AWD/XC 65K miles when should I change out transmission fluid? Is there a screen of filter that would need changed as well? Link to comment Share on other sites More sharing options...
Bay13 Posted July 23, 2005 Report Share Posted July 23, 2005 I read 24 with the comp engaged, 90-95 disengaged. I am taking it back in next week, they said my comp might be completely gone. Any thoughts on this?Pull the dip stick and look at the fluid, if it's brown, flush it. There is no filter to be changed. Link to comment Share on other sites More sharing options...
Guest Guest Posted July 25, 2005 Report Share Posted July 25, 2005 You take DEXRON IIIif you took the volvo synthetic, your dip stick would be about 9 inches and very hard to find. Your shifter would say, P R N D 4 3 2 L.But you can use Mobil 1 synthetic cause it's DEXRON III or equivilant if you want to use a synthetic or even Redline D4 which is what I'm using.←Okay, the more I read, the less I understand (yeah, it is a genetic problem).If I read this thread correctly, I can use Mobil 1 synthetic cause it's DEXRON III equivilant in any automatic Transmission, because it is okay to substitute Mobil 1 synthetic for Dexron III fluid. So, when in doubt, use Mobil 1 synthetic in your automatic transmission. Or Dexron III if you have the long tranny dipstick (15 and 1/2 inchs) and if you have the short tranny dipstick (9 inches ), you can use the Volvo synthetic or the Mobil 1 3309 specs synthetic (since they are the same). And Mobil makes the synthetic fluid for Volvo.Did I get it right? Bob Link to comment Share on other sites More sharing options...
