Black95-850T5R Posted May 21, 2005 Report Share Posted May 21, 2005 All of a sudden, it stopped moving and stayed in the middle like the car was shut down. I haven't touched anything yet. What to do/check to get it to function? :( Link to comment Share on other sites More sharing options...
merlin390 Posted May 21, 2005 Report Share Posted May 21, 2005 hows the car run? vac line might have popped off Link to comment Share on other sites More sharing options...
Black95-850T5R Posted May 21, 2005 Author Report Share Posted May 21, 2005 hows the car run?No, the car runs perfect normal. Link to comment Share on other sites More sharing options...
Zappo Posted May 22, 2005 Report Share Posted May 22, 2005 I would also say the line has been disconnected somehow. Link to comment Share on other sites More sharing options...
ziddey Posted May 22, 2005 Report Share Posted May 22, 2005 yeah it definitely sounds like the line popped somewheremy rubber elbow was eaten away on the inside bend part and it was losing vacuum/boost through there. as a result, my gauge only wavered a few degrees in either direction. after i pulled that elbow off, the gauge remained at 0 until i put a new one on Link to comment Share on other sites More sharing options...
T5BRICK Posted May 22, 2005 Report Share Posted May 22, 2005 yup. sounds just like a hose popped off.check under your throttle body and make sure the elbows are connected and that the caps are all in place on the unused lines. then follow the boost gauge line up to the firewall and check the elbows along the way. it's also possable that it popped off the back of your gauge cluster. Link to comment Share on other sites More sharing options...
prasamin Posted May 22, 2005 Report Share Posted May 22, 2005 i hope in your case that it just came off under the hood....if it came off behind the cluster, well, you know what that means, though once you do it, you get used to it and can pull it out in no time!! Link to comment Share on other sites More sharing options...
Black95-850T5R Posted May 22, 2005 Author Report Share Posted May 22, 2005 Thanks all. Well, I checked the line from the the TB to the firewall and everything is in its place, nothing popped off. So, it must be from behind the cluster. So, I guess I'll hook a boost gauge as I was intending to to do my stage0 and leave that. One more thing, the light(LED) for the fuel gauge was off a few days ago, and it came on today. What's happening behind the cluster :huh: Link to comment Share on other sites More sharing options...
KLS Posted May 23, 2005 Report Share Posted May 23, 2005 The middle point of the boost gauge is zero psi, or atmospheric pressure--no boost and no vacuum.Ken Link to comment Share on other sites More sharing options...
