mikie Posted May 26, 2005 Report Share Posted May 26, 2005 So I had an oil leaking coming from the front seal, it turned out to be a loose screw... But ever since I got that fixed I'm getting a lot of vibrations at idle. I don't see how this can correlate, does it? I noticed that oil was toped off (oil looks darker)... what if they toped off with non synthetic instead of synthetic which is what I'm using, can this cause a problem?Thanks,Mike Link to comment Share on other sites More sharing options...
MrWinkey Posted May 26, 2005 Report Share Posted May 26, 2005 Most synthetics are compatable with conventional oil Link to comment Share on other sites More sharing options...
mikie Posted May 30, 2005 Author Report Share Posted May 30, 2005 Most synthetics are compatable with conventional oil←thank you Link to comment Share on other sites More sharing options...
BlueTank Posted May 31, 2005 Report Share Posted May 31, 2005 Vibration at idle or low idle might point to cleaning the throttle body.All the manufacturer websites indicate you can mix and match synthetics and dino-oil. Link to comment Share on other sites More sharing options...
jbuck Posted May 31, 2005 Report Share Posted May 31, 2005 Vibration at idle or low idle might point to cleaning the throttle body.All the manufacturer websites indicate you can mix and match synthetics and dino-oil.←I've noticed that my car turns synthetic a darker color than dino oil.Is the vibration only at idle? Does it vibrate the same in neutral as in drive? Is it a steady vibration or does it come and go while idling? Link to comment Share on other sites More sharing options...
mikie Posted May 31, 2005 Author Report Share Posted May 31, 2005 In neutral there are no vibrations. My throttle body is clean. I had no vibrations until I got the car back from the dealer to fix the loose screw on the cam shaft. It's a pretty steady vibrations which seems to go through the entire car and kind of hurts your ears. Sometimes it's stronger then other times though but when its there it's fairly linear, it doesn't fluctuate.I'm figuring it could just be some of my engine mounts (lower ones). And it decided to happen as soon as it left the dealer just to comfuse me. Link to comment Share on other sites More sharing options...
jbuck Posted June 1, 2005 Report Share Posted June 1, 2005 No vibrations in neutral, I'd definitely check your engine mounts. My father inlaw's old 740 shakes like crazy when in drive, but idles quietly in neutral. Its got 350K miles on it and the engine is flopping around so I'm fairly certain the mounts are gone. He's determined to drive it "to the end" in its current condition. <_< Link to comment Share on other sites More sharing options...
jleilich Posted June 7, 2005 Report Share Posted June 7, 2005 Synthetic oil is darker than Dino oil.. And .. it gets even darker faster because it gathers up all the nastys in your motor. Link to comment Share on other sites More sharing options...
